Intermittent red triangle light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hugh_yup, Apr 17, 2012.
  1. hugh_yup
    hugh_yup Junior Member
    San Francisco
    It was driving me crazy that the red triangle warning light (master warning light) flashed for only a split second, once per day, two days in a row. I drive 100 miles per day. My 2004 Prius has 136K miles.
    It turned out to be low motor oil level, 1.75 quarts low. My car is burning about one quart every 5K miles which probably is within the normal range for a 136K car.
    With the synthetic oil common change interval of 10K, everyone should check their oil level at least halfway into the change interval, if not more frequently. Now I know to check the oil level more often …
    Does anyone know why there wasn’t a more friendlier and longer lasting warning message like “low oil levelâ€. I would have expected that.
    donbright likes this.
  2. Patrick Wong
    18,210
    6,514
    That warning would be quite reasonable to expect.
    Instead, you have to wait until the oil level drops so low that engine oil pressure is impaired, then you'll see a warning light. By then, the engine probably has been damaged due to insufficient lubrication.
    donbright, dave77 and hugh_yup like this.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Very few cars I know have any sort of oil level sensor and thus any low oil level indicator.
    BMW decided to get rid of the dipstick and instead replace it with a sensor which was/is apparently unreliable: http://priuschat.com/forums/other-c...es-cars-have-no-dipstick-starting-2006-a.html.
  4. uart
    uart Senior Member
    4,220
    1,211
    Australia
    The oil consumption has likely increased even more due to running with insufficient lubrication. So watch it carefully.
    I agree, that would be a good idea in my opinion. When there is just the one "idiot light" like this it would be really useful if there was a more specific warning as you suggest on the MFD (multi function display).
    I'm not very familiar with warning light, as fortunately I haven't received any yet. But I was under the impression that some "triangle of doom" errors are in fact accompanied with a more explanatory MFD icon. Like for example I thought that there was a thermometer icon and an engine icon etc that accompanied the triangle in certain situations. Can anyone elaborate on this?
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Driving those sorts of distances it might be prudent to actually check the oil with the dipstick every week rather than rely on the car to tell you. That way you won't have a problem. ;)
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    38
    Santa Fe, NM
    The red oil light will come on in the combination meter. But usually, people look at the MFD because it has the big red triangle.
    It will not store any kind of code either.
    An additional problem is that the oil pressure is often zero during normal operation -- stopped at a light, gliding, etc -- and triggering the light becomes a combination of conditions detected by algorithm. In addition, there is a pressure switch, rather than a pressure gauge, that determines the threshold, so there is a discontinuous boundary problem.
    Unfortunately, you may find that you motor consumes a lot more oil now. Check it every time you get gas. Try going back to 5W30, if you have been using 0W20.
    2 people like this.
  7. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I thought that the triangle was on the combination meter. Is it on the MFD as well? (I've never had the triangle so I don't know this stuff).
    Hi hugh_yup, did you also get the "engine" light as well as the triangle, like shown in this attachment?
    That's the extra information.
  8. hugh_yup
    San Francisco
    Thanks to all of you for your replies and good information that everyone can benefit from.
    I use to check the oil level more often when I was younger ... now I have to get back to that.
    My eyes were on the road when the dash lit up for only a split second. From the corner of my eyes, I could not tell if the "engine light" was also lit. All I remember is seeing a blur of a red triangle.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    When it's just flicking like that it generally means that it's sucking air (with the oil). The oil level is right down to the pump pick-up and and when you go over a bump or around a corner it can suck air and drop pressure. It's still really bad for the engine, but not as bad as no oil at all.
  10. vaquerfirm@gmail.com
    [email protected] New Member
    Savannah, GA
    Yep, mine did this last week and I quickly figured out it was low on oil.
  11. Seejay32
    Seejay32 New Member
    United Kingdom
    I've got a somewhat different problem. Occasionally the red warning triangle comes on when I push the start button. All the display comes up, but nothing else happens and the drive cannot be engaged. This morning I switched off and switched on thee times before everything was normal. I had a service at the Toyota dealership two weeks ago and asked for it to be checked, but they came back 'no fault found.' Car is 2007 T Spirit. I'd like to go back to the dealership with some idea what's wrong, so would appreciate any help. Thanks, sorry if this is in wrong thread
  12. seilerts
    3,326
    1,519
    38
    Santa Fe, NM
    You need a new 12V battery. Look for posts by Britprius on replacement options in the UK.
    2 people like this.
  13. Seejay32
    Seejay32 New Member
    United Kingdom
    Thank you seilerts, I'll certainly do as you suggest
  14. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Seejay check out Varta, Exide and Lucas for Prius batteries £40/£50 depending on where you buy and length of guarantee (up to four years). This is for a standard 45AMP/HR battery.
    If you wish for something with greater capacity and deep discharge recovery look at mobility batteries for wheel chairs etc, available in 55AMP/HR capacity for around £60 these are AGM liquid or gell batteries with a design life of 8/10years. Names to look for Haze, Lucas, Ritar, and Platinum amongst others. These batteries have screw in terminal posts that usually are supplied free with the battery. Size wise they are a direct fit.
    L 228mm, W 130mm, H 220mm. All sizes nominal. Prius battery has slim JAP posts and is positive on left with terminals closest to you.
    The OEM battery from Toyoa (not VG one year gurantee) last time I checked was £90 plus.
    In the US they swear by the Optima yellow top but hear it is way over priced at again last time I checked £184 this is a 38AMP/HR deep cycle battery.
    Do not go to Hal---ds they do not know what they are doing and are expensive.
    Check out Battery Bay UK (Cannock Staffs) I have no affiliation. Finally if you are disabled you do not pay VAT.
    2 people like this.
  15. pcdave
    pcdave Junior Member
    48
    Scotland
    Thanks for that post was about to ask the same thing intermittent flash of the warning triangle on start-up that goes away so far not had any issues with it but think the 12v must be on its way out.
  16. Rcmansid
    Rcmansid New Member
    The Dealer screwed us by saying the 12 V battery was low. They detected a leak on the oil filter but failed to check the oil.
    After spending almost 300$ on battery and their 119$ service fee. I find out the car was over 2 Quarts low which was the actual problem. Their mechanics need training on how to trouble shoot problems at that Dealership.
    dave77 likes this.
  17. BrendaT
    BrendaT Junior Member
    Houston
    Once again Prius forum has saved my day! 2006 186k miles and still best ride ever.
