Intermittent Red Triangle - not diagnosable ...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by frustratedInSeattle, Nov 8, 2025.
  1. frustratedInSeattle
    frustratedInSeattle New Member
    23
    Washington State
    Hi All,
    I'm new to the PRIUSchat, and I'm hoping someone here might have an idea what is wrong with my car. I am running out of money and patience.
    Background:
    My Prius has ~220K miles on it, and it has generally been a reliable car, except for the stupid touch screen part of the Mult-Function Display (MFD) that gave out, and no one will help me replace it, even though I found an after-market replacement. But I digress ...'
    The car burns very little oil. I have been using High Mileage Mobile 1 in it as long as I have had it (I'm the 2nd owner, bought it from a Toyota dealer when it had 150K on it). There don't appear to be any major leaks and the car runs pretty smoothly.
    The car sat for a long time during the pandemic, and during that time someone stole the catalytic converter. Fun! I didn't realize that was a thing before then. My local mechanic, who is honest and very nice, but not a hybrid geek, replaced it with an after-market converter and put a cage on it for me. After he fixed it, the dash was still lighting up like a Christmas tree, and he said he wasn't sure why. He knows I am not flush, so I'm sure he didn't spend a ton of time on it.
    The dash lights up like a Christmas tree, even though I've had many, many things fixed on it. The car is not worth fixing everything, I just want to get this damned triangle thing fixed.
    The Triangle Issue:
    So, this intermittent triangle thing started happening over a year ago. Yeah, I know, I should have gotten it fixed, but ... everybody thinks they know the problem, but no one can fix it.
    The Symptoms:
    At first, it seemed to be happening more often when I was doing highway driving in the rain. It does rain here once in a while, you know. A guy at an auto parts store, suggested it had to do with poor traction (I don't think he knew what he was talking about), but my tires were in pretty poor shape, so I decided it would be a good idea to replace them regardless. I replaced them with highly-rated Converse all-season tires. That didn't fix the problem, but it occurred to me that when I was doing that highway driving in the rain, I was also running the headlights, windshield wipers, radio and sometimes the defrost system. It gradually became more frequent, but it NEVER occurrs when the car is cold. It usually takes at least 10 minutes of hard driving (hills or highway and running the AC in the summer is a sure way to make it happen). So for short trips it's fine, although I can't run the AC when it's sweltering hot, even though the AC works. The heating system in the car isn't great, but I think (I haven't done a thorough test yet), that blasting the heat while driving may help, but I'm really not sure about that.
    Now if I only needed that car for around town, I could probably live with this, but usually drive out to see child who lives about 100 miles away, at least every 2-3 months. I have to cross a mountain pass, and the combination of the hills and the highway driving makes the triangle thing go on like crazy, even without running the AC in the heat. I really don't want to have to take the bus every time I visit. Also I sometimes have to do some driving for work, and a frequently see the red triangle then, too, although the drives are much shorter.
    Things I have done since that occurred:
    12 volt Battery
    Tires (good all-season)
    12 volt Battery
    Hybrid battery repair - CPU replaced)
    Spark Plugs and Ignition Coils (recent)
    Oxygen Sensor (recent)
    Hybrid battery diagnostic (recent - functioning fine for its age)
    Other diagnostics, including one from a Toyota specialist
    And of course the usual stuff like fluid changes, wipers, etc.
    Most recently, I took it to a shop with a good reputation, that has worked on quite a few Gen 2s and had all
    the Toyota diagnostic software for the hybrid battery system. I had a discussion with him before I brought it in, and he seemed quite confident he could find the problem. Well, he didn't!
    Like all the previous mechanics, he told me what he thought was wrong, and I told him why. He told me the ABS module was faulty, and that my front brakes needed to be replaced. He said he checked the hybrid inverter cooling system, including the pump and fan, and that they were working fine.
    I don't doubt that my front brakes should be replaced, even though the brakes seem to work fine, since it has been a long time since the brakes were done. But I'll be damned if I'm spending $1500 plus labor for an ABS module, on this car, especially with the Triangle problem. (Fixing the ABS brake module is likely to break me!) I explained to him that the intermittent red triangle problem NEVER occurs when I am braking. It typically occurs while high speed driving, while running the Air condition, and when accelerating (especially on an incline) - running accessories (especially the AC) seem to make it occur more frequently. He told me he had to follow the procedures outlined by Toyota. He also wasn't able to reproduce the problem, which is not surprising, since he didn't take it out on the highway. I offered to take it out for a spin on the highway, and bring it back with the issue, but he reiterated the bit about following the recommended procedure. I might have him replace the front brakes, since that's a safety issue, but I don't want to sink more and more money into stuff that won't fix my red triangle problem
    So, do any of you have an idea what might be going on and/or where I should take it? I am reluctant to take it to a Toyota dealer, since they would likely run the same diagnostics as the Toyota specialist I saw. Whatever is happening with the car is not showing up on the diagnostics. I really want to find someone who is able to diagnose it even though the codes are not really telling what is going on when that red triangle comes on. It really needs to be someone who is intimately familiar with older Priuses. The mechanics I have taken it to were all pretty experienced.
  2. frustratedInSeattle
    23
    Washington State
    I forgot to mention, that the triangle light will go off pretty quickly if I go on an extended coast (when I am not pressing the accelerator), as long as I am not running the AC, but when I am doing extended highway driving, especially in the summer, I periodically have to stop and let the car cool down for about 5 minutes. The cooling systems seem to be OK, and the temperature light never goes on.
  3. JC91006
    16,936
    8,647
    Well I can't imagine a proper mechanic can't figure this out. There will be codes that will point you to a trouble area.
    You may have multiple issues with this car. Brake actuator for $1500 is almost guarantee on a 2006 Prius, they fail and they all need replacement. But the $1500 is probably a quote for a used unit as new units will be that price, and you have to add labor.
    You should probably check your cooling system to make sure everything is working. You might have a cooling issue with the water pump (or belt) or just air in the system with low coolant. This should be something that's easily fixable if that were the case.
    But you can also have experienced the issues if your tire sizes were not the same. If you have a bigger tire on the left and a smaller tire on the right side of the car, that could cause those lights to go on as well.
  4. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    Out of all the speciality meccies working on car no codes anywhere in sight hmmmmm.thats a start .so it's all Amber lights except red triangle . At triangle displaying they're are codes sonone has to retrieve them . And you're in what state ??
    Brian1954 likes this.
  5. frustratedInSeattle
    23
    Washington State
    Well, yes, there are codes, but I have had them fixed, and they still come up. The codes say that I have misfires in cylinders 1 and 2, and I had all the spark plugs replaced w/ NGKs only 500 miles ago. There was also a catalytic converter code which everyone said was likely the oxygen sensor, and it replaced them with the OEM (Denso). I told them that before they looked at the car, but they seemed to ignore what I said. He told me about the misfires (which I knew about) and when I told him about replacing the plugs and coils he had a blank look on his face like he was hearing it for the first time. Honestly, But there aren't any codes coming up related to the Red Triangle!
    Honestly, it's frustrating that I explained everything to the guy at the desk, and he seemed to listen to me. Then when I pick it up (same day, just a few hours later) he acts like he never heard what I said. I don't know if most of the people he sees are dumb or what, but he wasn't telling me anything I didn't know (except for the brake issue). I told him what I needed to be diagnosed, and he didn't diagnose it!
    As for the cooling systems (I understand there are two - one for the engine and one for the hybrid inverter) and the most recent mechanic said both the pump and the fans were working. I was a little annoyed at the terse description. I would have expected an estimate to fix what they did find (even though it doesn't have to do with the red triangle), including the parts needed and labor charges. He called the verbally said it needed the ABS module, but in the description it says ABS booster. It very well might be the brake actuator. A part number would have made that a lot clearer. He sent me a link to the report, since his printer wasn't working. I wish I had looked at it while I was there. I will call back during the week, and see if they can give me an estimate. An diagnostic isn't much good if you don't communicate it properly to the customer!
    Here is what they wrote in the mechanic wrote in the diagnostics.
  6. frustratedInSeattle
    23
    Washington State
    I especially love the line "Trust our expert team to perform the necessary repairs and get your vehicle back on the road in top condition", since they didn't diagnose the biggest problem with the car!
    Note: Coils were replaced after codes still came up.
    #6 frustratedInSeattle, Nov 9, 2025
  7. frustratedInSeattle
    23
    Washington State
    I am in Western Washington, near Seattle. I would happily drive to any nearby major city - Tacoma, Puyallup, Lynnwood, etc. if there was a good mechanic there. But at this point, I'm getting really frustrated. Whatever is causing the triangle issue isn't showing up on the OBDII scanners, nor the fancy Toyota system that the last guy had.
    #7 frustratedInSeattle, Nov 9, 2025
  8. frustratedInSeattle
    23
    Washington State
    Also when the Red Triangle pops up, the display reads "There is a problem."
    I want to scream at the display, "No shit, Sherlock! Now, Wth is the problem?"
    The Red Triangle never comes up when I am braking. Always when I have my foot on the gas, especially when I am accelerating, going up hill, or running the AC (which I never do anymore).
    #8 frustratedInSeattle, Nov 9, 2025
  9. Hayslayer
    Hayslayer Active Member
    538
    331
    Sounds like you have a few problems, but many symptoms point toward inadequate cooling in the inverter cooling system. The inverter cooling water pump is located directly behind the driver side headlight. They have a couple failure modes and can do anything from an electrical short (where you get a burning smell, blows the AM2 fuse and kills the car) to just intermittent operation where it appears normal today but never even starts tomorrow. There's also the possibility there's a clog in the system preventing adequate flow in some passages.
    If this is the case, a CEL should be triggered, yet none of the mechanics provided you with codes?
    As for the catalytic converter issue, the gen 2 has an upper, a lower and an O2 sensor between them. When these were being stolen during the pandemic, the pipes were usually sawed above the upper converter and then after the lower converter, and then they would just snatch it out, ripping the O2 sensor wires apart. Sometimes this would be obvious because partial wires would be hanging down and other times, the wires would rip apart further up and be not so obvious. Did he install a new assembly with an upper and lower cat + O2 sensor, or just weld in a converter and some pipe only? The O2 sensor wires are plugged into the car harness under the carpet on the passenger side of the center console.
    frustratedInSeattle likes this.
  10. Brian1954
    Brian1954 Senior Member
    2,689
    1,076
    South Central PA, USA
    You have provided a very nice description of the history of your Prius. One of the most important pieces of information that you have not provided is "what are the trouble codes when the red triangle comes on". I am very surprise that the hybrid mechanic did not let you drive the car until the red triangle came on so that he could then read the trouble codes. Determining all the trouble codes is the very first step that needs to be done for diagnosing the problem. Until you have all the trouble codes, you and everyone else are just guessing what the problem(s) are with the car.
    You can buy a Bluetooth OBD2 scanner and an app for you phone to read the trouble codes yourself if you are interested in doing that. The Autel AP200 is about $60 to $70 on Amazon,
    Autel MaxiAP AP200 OBD2 Scanner Bluetooth Wireless OBDII Auto Diagnostic Tool with Full System Diagnostic
    #10 Brian1954, Nov 9, 2025
  11. frustratedInSeattle
    23
    Washington State
    I am not going to buy a scanner when every time I've gone to the mechanic they have scanned it, and told me the same codes, even after I have fixed what the codes supposedly indicate. I have I don't have them at this time, but I will post them later. The problem is, these codes aren't helping diagnose the triangle issue.
    Since I do not have a garage and I am not permitted to work on the care where I live, having an OBDII scanner would not be that useful to me. If it's something quick, like filling coolant or whatever, I can get away with "working" on my car, but not anything that would take some time. During the pandemic, 12V battery died (really died), and none of the auto stores were putting in batteries, so I told the office I needed to replace the battery. I didn't think that would be such a big deal. It's not like changing the oil, and possibly having it leak on the pavement. They told me they would get back to me. I ended up changing it overnight while it was cold and rainy. What a pain in the butt! I had to climb through the car to get to the hatch area, since there is no key lock for the trunk, and figure out how to open the hatch without power. The next day, they told me that I needed to get the car towed. How ridiculous! I said "Oh, so sorry," (not sorry), "I already replaced it."
    #11 frustratedInSeattle, Nov 9, 2025
  12. JC91006
    16,936
    8,647
    Reading these comments leads me to think this car was probably not repaired properly and the OP does not want to spend the money to do it correctly.
    a bad catalytic converter, especially an aftermarket crappy one, always comes up as a problem with the part itself, not the sensors. They cost 1/10th the cost of an original part, and there is a reason for that. So this repair even though it's been done, was not done correctly with a long lasting reliable part.
    I feel the entire history of this car is that it was not repaired correctly and the parts used may or may not have been the correct parts. No mechanic will go by your word and chase down problems they didn't originally fix. You changing the spark plugs/coils, does not mean those plugs are good parts or installed correctly.
    So your hands are tied at the moment, real mechanics can't help you as whatever they suggest you would have the answer of "I've already done that".
  13. frustratedInSeattle
    23
    Washington State
    There is certainly a possibility that the after-market catalytic converter isn't working properly. I was surprised that he did that. I didn't ask him to do that, I expected he would have charged me more. But I sure don't want to replace that catalytic converter if that is not what is causing the Triangle Problem. My understanding is that the triangle issue usually has to do with the hybrid system not working correctly, if someone can tell me how the converter going bad could affect the system, I would be interested. Putting in an OEM catalytic converter is a huge expense.
    As for the plugs, coils (and virtually everything else) - I paid mechanics to do that, even though that's a pretty easy job and could have done it myself if I had a garage.
    Are you suggesting I replace the plugs and coils again, even though they were just done, and the car runs smoothly, except when the triangle light comes on?
    As for not wanting to pay to fix it properly... I have already paid good money to have the car fixed properly! What I don't want to do is pay thousands to not fix the problem. The car is not worth that. This is the third mechanic that examined or worked the car since the triangle light appeared (not including the hybrid battery specialist), but it was the first one that had the Toyota-specific diagnostic setup. That's what really frustrated me.
  14. ChapmanF
    19,035
    That's exactly the question, and the car wants to help you answer it, but a scan tool is how that's done.
    That's not the fault of the codes, but of whoever is interpreting the codes. Typically when a story has "even after I have fixed what the codes supposedly indicate" in it, it's a story where someone has made overly-narrow assumptions about what the codes indicate. One way that often happens is a person sees that a code's one-liner fortune cookie has the name of Part X in it, so therefore thinks "this code is telling me to replace Part X".
    It's important to remember that trouble codes are information, not prescriptions. The ECU is telling you as much as it can about how it noticed something's hinky. It isn't telling you—and has no way of telling you—what the root cause of that is, or what actions on your part will solve it. The ECU just isn't capable of climbing out of its box and crawling through the engine bay with instruments to find out what really caused the hinky data it got. There has to be a human willing to do that part.
    That takes more than just looking at the fortune cookie; it takes looking at the actual troubleshooting steps (often several pages of them) given for a particular trouble code in the Repair Manual, and working through those steps, and seeing what they reveal.
    The one-liner fortune cookies are only useful as memory jogs for technicians who have been through troubleshooting that code before and can be jogged to remember how to do it.
    As for us on the other end of the internet here, we can't offer much help if all we know is there were some codes and you did what you thought they were telling you. If we know what the codes were, we can usually offer more.
    Brian1954 and PriusCamper like this.
  15. Hayslayer
    538
    331
    We can probably help you a lot more once you post those codes. You have guys here who have probably worked on more Gen 2s than the shops you're going to and 100X their experience in the seat. Help us help you. If they gave you a printout of the codes or a receipt that shows what they did, throw a photo up. Let us decipher it.
  16. PriusCamper
    PriusCamper Senior Member
    13,467
    5,435
    Pacific Northwest, USA
    What are the error codes the mechanic found? Is your oil level normal? I'm an hour south of Seattle and if you can get here I can swap out your MFD in a 1/2 hour and only charge you $25 in labor...
  17. Brian1954
    2,689
    1,076
    The only trouble code that I have seen so far is in post #5, which was C1355. I believe that code will turn on the red triangle. Maybe someone else can confirm that or tell me that I am wrong.
    It appears that the OP has multiple problems with his car.
  18. ChapmanF
    19,035
    The C code is a Chassis code (from the brake system), and I didn't think those usually turned on the triangle, but I'm not saying I'm sure. I don't have a gen 2 repair manual open right now.
    I'd expect the triangle to be on more likely for a P code.
    I think a C1355 can identify around four possible issues involving the pressure-increase solenoid for the left rear brake, depending on what INF code goes with it.
  19. bisco
    52,863
    <popcorn>
  20. frustratedInSeattle
    23
    Washington State
    Oil is fine - clean and full. Awesome regarding the MFD, but that's not my big concern right now. I will post as codes as soon as I get them.
