Intermittent Red Triangle - not diagnosable ...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by frustratedInSeattle, Nov 8, 2025.
  1. frustratedInSeattle
    frustratedInSeattle New Member
    23
    Washington State
    I'm really skeptical about the cause of the triangle having anything to do with the brakes, since it never happens when I brake, always when I am depressing the accelerator. I will stop into Les Schwab on Tuesday to have them check the front brakes. I wouldn't be surprised if I need new pads and rotors, but I just like to get a second opinion. I wasn't there to see them. I will call the mechanic on Monday to see if I can get more information.
  2. frustratedInSeattle
    23
    Washington State
    The last thing I want to do is replace expensive parts that don't fix the critical Triangle Issue. I am also a bit concerned that the mechanic just hooked up the car and diagnosed it without doing some thorough investigating. And yes, I understand about the codes have multiple causes, but of course I have been relying on what the experienced mechanics believed.
    Others have mentioned that there are probably multiple things going wrong, and that is undoubtedly true. For instance, I have chosen not to fix the tire sensors. I just check their inflation periodically. I need to fix what is most critical. I need to keep the car going for work, even if I can't drive it out to see my child. There is no way I can buy another car right now. I am paying off a lot of medical debt. I don't have any extra money in my budget.
    Please stay tuned, I will post as soon as I know more info, including all the codes.
  3. PriusCamper
    PriusCamper Senior Member
    13,467
    5,435
    Pacific Northwest, USA
    They're going to try to sell you a brake job whether you need one or not. Hold on to your money until you get this figured out.
  4. frustratedInSeattle
    23
    Washington State
    Oh yeah, I just need to see what kind of shape they are in. They shop claimed the front brakes were metal on metal, which seems strange since they aren't making any noise. I will get them done if they are really that bad, but probably not from Les Schwab. They use OEM parts, so are pretty expensive. I would just get some decent quality after market.
  5. Hayslayer
    Hayslayer Active Member
    538
    330
    C1355/27 Rear Increasing Pressure
    Solenoid LH Malfunction
    Possible subcodes:
    43
    44
    Possible problem areas:
    - Brake actuator assembly
    - Skid control ECU
    - Harness and connector
    But anyway..............I wonder what would happen on the dash if extremely worn brakes caused a low level in the brake fluid reservoir..........
    frustratedInSeattle likes this.
  6. ChapmanF
    19,034
    A low level in the brake fluid reservoir, from whatever cause, triggers a C1202 code, which turns on the brake warning light.
    Typically, the ABS and VSC lights will come on as well; if you ask them for blink codes, they'll blink 42 and 45, respectively, meaning "what are you looking at me for? go look at the ECB code." The ECB light would blink 52, which is the blinked version of C1202.
  7. frustratedInSeattle
    23
    Washington State
    Good Point about the brake fluid. I will check that, too. That won't cost me any money. I topped off the coolant in both reservoirs. It was only down a little in the one for the inverter, but the radiator reservoir was down some. I will check the brake fluid tomorrow. Still, I don't understand why the triangle light would come on when I'm not braking.
  8. frustratedInSeattle
    23
    Washington State
    Wow, these are all excellent ideas! My gut feeling is that there is something wrong with the cooling system, but they said checked it. However, that idea of a possible clog somewhere is intriguing. That might be something that isn't obvious, unlike checking belts, fans and pumps. Are there any filters in the system that might get clogged? I suspect that the shop I took it to with the Toyota diagnostic system might have exaggerated their Prius knowledge. I used to drive a Subaru, and I went to this guy who was a real Subaru guru-type. I wish I could find someone like that who really knows Priuses.
    As for the catalytic converter, I'm really not sure. He is a sharp guy, but he has done some weird things. Like, I asked him to replace both headlight bulbs when he did an oil change (I provided both), but he only did the one that was out. He said there is no reason to do both. Sure it's not critical, like brakes, but it irritated me. Since the dash lights were still on after he replaced the converter, that's certainly possible. I think your idea about the wires being damaged is good.
    I used to live near a friend with a garage (normal one, not a mechanic shop). We sometimes worked on cars together. I miss the friend and the garage.
    #28 frustratedInSeattle, Nov 9, 2025
  9. JC91006
    16,936
    8,647
    Are you topping off the coolant in your actual radiator? The radiator cap is hidden under the front engine cover. The reservoir won't usually do much if your radiator is not full. That could be the reason the car is overheating and you're seeing the triangle.
  10. frustratedInSeattle
    23
    Washington State
    No, I fill the reservoirs. The actual engine radiator was low, but after filling the heat/defrost worked better, but it didn't fix the triangle issue. My understanding is that since the radiator is a closed system, you don't want to fill the radiator through the cap, because that will introduce air into the system. I will recheck the reservoir this morning.
    The car has not turned on any lights that indicate overheating. I just suspect that the cooling system for the inverter isn't working properly. But the high temperature icon hasn't gone on.
    #30 frustratedInSeattle, Nov 10, 2025
  11. JC91006
    16,936
    8,647
    Your understanding is incorrect. Your radiator is most likely low, that's what you need to fill (when the engine is cold). check the radiator cap while you're at it, if it's bad, replace it ($10).
    The triangle is a good indicator that something is wrong (like low coolant)
  12. Brian1954
    Brian1954 Senior Member
    2,689
    1,076
    South Central PA, USA
    The red triangle (master warning light) indicates that there is a problem with the hybrid drive system in the car. I do not think the red triangle will come on for an overheating engine.
  13. JC91006
    16,936
    8,647
    I can say it does because I've experienced it twice.
  14. frustratedInSeattle
    23
    Washington State
    OK, you were right!
    The radiator was way down. I wonder if I have developed a leak? I filled it up during my lunch break. I will check what it looks like after work. Thank you for the suggestion. I even mentioned this to to the Toyota "specialist", and he said, "how do you know the car is overheating?" I said, "I don't, but I never get the triangle when the car is cold. It has to be running at least 10-15 minutes, and it happens more quickly when it is hot outside." I guess he discounted what I said, since he obviously didn't check the radiator. It seems like a lot of mechanics just read the codes, and don't do much investigation.
    I still haven't got the codes or had the brakes rechecked. I did check the brake fluid though, and it was completely full.
    Brian1954 likes this.
  15. JC91006
    16,936
    8,647
    it'll take 3 or 4 days of filling that radiator for all the bubbles to bleed out. So for the next few mornings, fill the radiator until it is full. Do that until the day it is completely full when you open the cap.
    Then cross your fingers and hope your problem is resolved with the coolant. Monitor for leaks and I would probably replace that radiator cap with a new one.
    #35 JC91006, Nov 10, 2025
  16. PriusCamper
    13,467
    5,435
    You sometimes can hear gurgling in the dash, or hear the electric cooling fan on the radiator running when you're low on coolant. As for how you got low, get under the car and look at the passenger side of the engine for signs of dried up red coolant. That's wear engine water pump is and when it fails you can loose coolant that way.
  17. frustratedInSeattle
    23
    Washington State
    I've never heard these things, but I have a hearing deficit, so there are many things I don't hear. I have looked under the car for coolant, and have not seen any, except for when I've been sloppy refilling it. Seattle is a little difficult, though, since it is always wet this time of year.
  18. frustratedInSeattle
    23
    Washington State
    Yes, that's what I've been doing. Today, I drove the car to Tacoma to test it out, and NO RED TRIANGLE!!! It was also an excuse to stop in a store I've been meaning to go to. I made an appointment to have the brakes inspected Saturday (I wasn't keen on a 2 1/2 hour wait). I will ask them while they have it on the lift if they notice any leaks.
  19. frustratedInSeattle
    23
    Washington State
    OK, so I called the mechanic that just looked at the car, and he said "Well, there were like 20 codes, but I cleared them out before I took it for a [useless,10 minute] test drive. I didn't write down any of the codes before I cleared it."
    That's pretty annoying in my book, since he didn't even take it on the highway. I wish he had let me do it.
    But here are the remaining codes right now:
    Body control module
    P0420
    P0301 and P0304
    Note that these codes have probably been on since the original catalytic converter was stolen. The mechanic who replaced the converter said he couldn't figure out how to get rid of them at the time he replaced it. I recently had the O2 sensor, plugs and ignition coils 1 & 2 replaced.
  20. PriusCamper
    13,467
    5,435
    Sounds like ignition coil # 4 probably needs to be replace too.
