Intermittent thermometer (beep, red triangle of death, problem, thermometer)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Marcilla Smith, May 25, 2018.
  1. Marcilla Smith
    Marcilla Smith Active Member
    140
    125
    Raleigh, NC
    OMW home from work on I-40 and the car beeps, the RTD comes on, then the display says "problem," followed by the thermometer over the wavy lines. The warning lights go back off after a few moments, sometimes after only a few seconds. Then they reappear and again disappear.
    I took it to my mechanic who made sure to top off both reservoirs. When it continued to do the same, he said I might need to ask the dealer on this one.
    Similar threads I have seen are quick to mention the possibility of air in the system, but also other root causes have been identified in some instances.
    I have a techstream, but only just got the sw installed today and I'm not really sure how to fully make use of it :: sigh ::
    Is there a troubleshooting guide, or other guidance available, please?
  2. Patrick Wong
    18,210
    6,517
    Check the coolant level in the radiator, do not rely just on looking at the reservoir. You need to remove the large black plastic panel over the radiator for access to the radiator cap.
    Also look at the inverter coolant reservoir when the Prius is READY. Do you see fluid turbulence which shows the inverter coolant pump is working?
    Marcilla Smith, Raytheeagle and SFO like this.
  3. Marcilla Smith
    140
    125
    Raleigh, NC
    TY for the assistance. After letting the car sit to cool off, I removed the black plastic panel and radiator cap. There was coolant all the way to the cap.
    The inverter coolant reservoir shows lots of turbulence. Both of the water pumps have been replaced w/in the last 1,000 miles, FWIW (I anticipated I would need to replace them when I purchased the vehicle in March).
  4. Marcilla Smith
    140
    125
    Raleigh, NC
    Wait... ready, or ig on?
    When I press the button once, there is no turbulence. Turbulence is present if I press the power button twice, or if I press it while holding the brake
  5. JC91006
    16,936
    8,647
    Make sure you check all vital fluid levels. But it does sound like your problem is coolant/temperature related. You'll need to read the codes on the car to pinpoint the issue. Maybe a bad thermostat or air trapped in the system since you last serviced the coolant 1000 miles ago
    Marcilla Smith and Raytheeagle like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    How long has it taken to put on the 1000 miles?
    If you don’t do much freeway driving then did a trip for the first time since the change in pumps, there might be air in the system.
    Was the thermostat replaced along with the water pump?
    Marcilla Smith and JC91006 like this.
  7. Marcilla Smith
    140
    125
    Raleigh, NC
    TY for the follow-ups.
    The thermostat was not replaced with the pumps. Do I need to go back and have that done?
    I don't know that it's been 1,000 miles, but more than 100, certainly. My commute is about 10 miles one way.
    The most recent service to the coolant system was the inverter pump replacement 2 weeks ago.
    Can I read the codes if the warning lights go back off? I have a Techstream, and it is connecting to the vehicle, but I'm unfamiliar with using it :/
  8. ChapmanF
    18,996
    You can ask it for a Health Check, and see what codes (current and/or historical) come up.
    Beyond that, you can go to either the Engine or the Hybrid Control screen and pull up the Data List, and watch the temperatures (engine coolant or inverter coolant, respectively) while you warm the car up. Just to see how it behaves. For example, does the engine coolant temperature rise fairly steadily up toward 85 or 90 celsius, and then slow down and level off around 90ish as the thermostat opens?
    Somebody else may have to chime in with how the inverter coolant temperature behaves normally. One nice thing is there are multiple temp sensors in the inverter and transaxle, so you can see if there's a hot spot in one particular place, for example.
    If you have a passenger to watch Techstream while your eyes are on the road, you can see what the temperatures do while driving. (You can also have Techstream record them while you drive, and graph them later.)
    -Chap
    Marcilla Smith likes this.
  9. Marcilla Smith
    140
    125
    Raleigh, NC
    Thanks for more information.
    I do not see that I have a "health check" button in the left hand column. Also, I do not have a "utilities" button. Am I missing part of the installation?
    Sitting here parked, the coolant temp reads 204-217 F (96-103 C). HC coolant temp reads 210-221 F (99-105 C).
    How do I have Techstream record while I'm driving?
    I saw there was a P0A93 code, but IDK if that was still there from before the inverter pump change. I cleared the code, so now I'll have to drive more and see what happens? I guess I can figure that much out on my own, at least
  10. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    What version of Techstream do you have?
    There are plenty of temps that you can monitor, but from what you are reporting here, the temps seem elevated:(.
    I’d have someone else in the car with me and then they could watch Techstream while you drive so the behavior can be noted;).
    Next step I’d do if the temps confirm high would be to pull the thermostat and check it’s functionality.
    Keep us posted (y).
  11. Marcilla Smith
    140
    125
    Raleigh, NC
    TY for staying with me!
    I will have to check on my TS version and report back.
    What constitutes a "high" temperature? It seems to want to run in the 250's (F) when driving.
    Raytheeagle likes this.
  12. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    That’s much higher than normal:(.
    I’d be looking into the thermostat;).
    Should run around 195 F.
    Keep us posted (y).
  13. ChapmanF
    18,996
    Yes, that's alarmingly high. The car should have something like an 85 or 90 degree (Celsius) thermostat (that's about 185 to 194 Fahrenheit). (I think the lower number might have been for Gen 1.) If the temp continues to climb above there, the fans should kick on around 95 C / 203 F. Is that happening? At 250 F you should definitely have fans on full blast.
    I wondered for a long time what could even lead to a thermostat failing closed, since it's really a pretty bulletproof bit of technology. Turns out the one possible cause of failure is some severe overheating originally caused by something else ... thermostat opens as wide as it can, further temperature increase splurches out the expanding wax, then it's an ex-thermostat. Then if you fix whatever caused the original overheating in the first place, you still have overheating because of the now-splurched thermostat.
    -Chap
    Marcilla Smith and Mendel Leisk like this.
  14. Stimp
    Stimp Member
    53
    North Carolina
    Since it has been so hot in NC lately you probably have not used the heat in your car since the coolant replacement. Simple thing that could be tried would be to run the heat at max temperature. Would circulate coolant and if there is air in the system, that would hopefully purge it.
    Confirm that the correct coolant was used, if there was something different in there before, or put in after it could have gummed things up. Mixing coolant types can do this, and enough is left in the engine loop after a drain to cause problems.
  15. ChapmanF
    18,996
    The standard, pleasingly low-tech test for a properly operating thermostat is to twist some wire around it and hang it from a utensil across the top of a pot of water on the stove, so the thermostat is hanging down in the water. Start heating the water, stick in a thermometer (capable of reading up to 100 C / 212 F without damage). The 'stat should be full open at the temperature stamped on it. That either happens or it doesn't; if it doesn't, you've got your culprit.
    -Chap
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    250's will cook the motor. It will warp the aluminum cylinder head. It should never run hotter than 190-200.
    You have alot of air trapped in the engine coolant loop. Turn on the car's heat and listen for gurgling sounds under the dash. You never said who did the engine coolant change but if they opened the engine block drain they are in for a long day. At the very least the CHS motor has to cycled by TS to purge any trapped air. Seen this post a thousand times on this site.
    I did a full coolant dump years ago and it sucked. It was a real pain to get all the air out. Its a modern car issue where now the cylinder head is actually higher than the rad and that tends to trap air bubbles in the worst place possible the aluminum cylinder head. Which is really easy to damage with high heat. Compounded in this car by the coolant heat recovery canister not allowing coolant flow.
    Be very careful here because you can easily toast the motor on one good overheat which you are already seeing. There is no temp gauge so driving around and waiting till the thermometer to pop up with be very $$$$.
    The trapped air needs to be bled by ts cycling of the canister and bleeding using the rad petcock.
  17. Mendel Leisk
    42,310
    If the thermostat is relatively cheap purchase, I'd get a new one, just since you're going to all the bother of pulling the old one out. Then, hang both in a pot of water and slowly bring up the temp, watch the difference in performance. Also compare the condition of the rubber gaskets on both.
    Basically you make a "race" of it, and the differences between the new and old are very easy to tell.
    Doing that exercise decades back, for starters, I noted the rubber gasket on the old thermostat was definitely more frayed/brittle, with a few bits missing. And hanging in the bath, the old one opened a lot sooner. In my case the old thermstat was overcooling.
  18. Marcilla Smith
    140
    125
    Raleigh, NC
    Thanks for all the info. Please excuse me if I have to ask for a little more...
    I'll get the thermostat changed, NP. For the future, I guess that's a good idea to always include with a water pump change?
    CHS = coolant heat storage? rad = radiator? TS = Techstream? Are you saying I should be able to initiate cycling with my Techstream?
    And on that subject, the version I have is 12.20.024.
    As for the coolant, I gave my mechanic the pink SLLC to use. When I brought it in yesterday, he added a little universal to it
    #18 Marcilla Smith, May 26, 2018
    Stimp and Raytheeagle like this.
  19. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    That was the version I had prior to going back to 10.30.029;).
    The 10 version for me has the utility menu in addition to all of the other ecu menus working:).
    Something to consider (y).
  20. ChapmanF
    18,996
    If you get the thermostat changed, I'd suggest asking for the old one back. Then you can stick it on the stove and boil it and see what temperature opens it. If it shows as definitely failed closed, then you can be confident it was your problem and that your car is probably fixed. If it performs well, you'll know it wasn't your problem, and you're not out of the woods yet.
    In general, if the reason for changing the water pump is that it failed and the engine got way hot, then changing the thermostat makes sense, because the wax might have splurched out.
    If the WP was changed for some other reason (noise, bit of seepage, etc.) and the engine never overheated, and you're not having slow warmup problems like Mendel with his early-opening one, the old thermostat is probably still fine. Something built out of a spring and some expanding wax just doesn't have all that many ways to go bad.
    -Chap
