Internal led replacement
Discussion in 'Prime Accessories and Modifications' started by jonespita, Feb 5, 2017.
  1. Elbrad
    Elbrad Junior Member
    53
    24
    Nanaimo, BC
    Whoops...my bad.
  2. always_shifting
    always_shifting Junior Member
    US
    I just went ahead and started swapping out my LEDs in the vehicle. So far I've tackled the door accent lights and the trunk light, all easy enough.
  3. always_shifting
    US
    I used these lights from Amazon for the trunk, door accent lights, and map lights.
    https://goo.gl/YZAbh1
    I am going to pull the trigger on a different set of similar lights on Amazon to try an even higher output from the trunk which is always a poorly lit area. I have also ordered a new dome light with LEDs. I will report back how successful I am. Maybe some pictures too.
    Also, has anyone tried swapping out the LEDs for the footwell lighting? I would love for that to be a white color to match, or maybe a blue to match the accents in the Prime.
    #23 always_shifting, Mar 6, 2017
  4. prius2017prime
    prius2017prime Junior Member
    Hawaii
    2023 Prius Prime
    XSE Premium
    Got rid of the dim yellow incandesces and picked up a package of Yorkim LEDs from Amazon.
    Used T-10 LED, #168 cross reference LED for the (2) center map lights, (2) vanity mirror lights, (2) door panel lights, and (1) trunk/cargo light. You need (1) DE3275 LED for the back seat dome light.
    For install instructions, you can search YouTube, “Toyota Prius LED Interior How To Install - 4th Gen 2016+” and pick up a set of LEDs from PrecisionLED.
    Xzen808 likes this.
  5. rockryno
    rockryno New Member
    NorCal
    talker2 and alexcue like this.
  6. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Thanks guys. Swapped out all the interior lights to LED. Nice looking little mod. Cheap too... I'll check them tonight especially the door lights.
    The map lights took me the longest. But it's actuallly easier than that YouTube video shows, but it's still scary to finally work loose.
    Man those little halogens got hot! The LEDs are also much cooler.
    I left the footwell lights alone. I don't know where they are hidden.
  7. Karthik Krishnan
    Karthik Krishnan Junior Member
    Can you please provide me the exact LED Part # for the back seat dome light? I am unable to find DE3275 on Amazon or eBay. Thanks.
  8. Phildgreat
    Phildgreat Member
    73
    44
    Los Angeles
    Which bulbs did you end up getting? I'm highly interested in swapping my bulbs out to LEDs too so appreciate the feedback. Keep it coming.
  9. alexcue
    346
    311
    So Cal
    Prius from Dad likes this.
  10. Prius from Dad
    Prius from Dad Senior Member
    724
    1,115
    Toms River, NJ USA
  11. Washingtonian
    Washingtonian Senior Member
    710
    608
  12. Washingtonian
    710
    608
    To answer my own question. Just received a reply from the seller and he states they will work for the Prime. Just placed my order.
    Prius from Dad and alexcue like this.
  13. Karthik Krishnan
    Can someone give me a link or specification to buy the Rear passenger dome LED bulb? I already ordered the other LED bulbs from eBay to replace the map light bulbs, the vanity bulbs and the door bulbs. But struggling to find the right dome bulb for the rear passenger seats. Also, I notice that the License plate bulbs are already white LED lights. Do I need to replace these too?
    10 PCS LED Xenon White Wedge T10 5050 5-SMD Light bulbs 192 168 194 W5W 2825 158 | eBay
  14. alexcue
    346
    311
    So Cal
    Maybe this will help
    2016 Toyota Prius LED Lights | Super Bright LEDs
  15. Prius from Dad
    724
    1,115
    Toms River, NJ USA
    Using Alex's link, this is the one you want.
    alexcue likes this.
  16. Karthik Krishnan
    alexcue likes this.
  17. Prius from Dad
    724
    1,115
    Toms River, NJ USA
    alexcue likes this.
  18. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    yes
  19. kellyj
    kellyj Junior Member
    40
    Orlando, fl
    2019 Prius
    did this one fit? I ordered a set off eBay and all fit except the map light was too big, it fits but is stretching in the fixture contacts a bit. Would prefer a better fitting bulb. Thanks in advance.
  20. MrMimizu
    MrMimizu Junior Member
    TOronto
    2019 Prius Prime
    Went to the superbrightled website.
    They're suggestion two different options.
    One is just regular leds, the other is "canbus" which they said may be needed in newer cars.
    Does it matter for the Prius Prime?
