Internet Explorer has stopped working?
Discussion in 'Fred's House of Pancakes' started by Mendel Leisk, Feb 21, 2015.
  1. Mendel Leisk
    42,361
    My Internet Explorer is completely hooped this morning. I've not installed anything of late, I think. Well, mighta updated ITunes in the last day or two. And Windows could have done an update in the background. Using FireFox (shudder) right now. Just wondering if anyone else is having problems? I'm running Windows 7 32bit, latest IE, version 11 something?
    I tried through control panel, to put all IE settings back to defaults, no difference.
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    It's trying to tell you to use Chrome or any other browser available, politely.
    I'd be concerned about a malicious program inhibiting my computer.
    Start,run, (type) msconfig, go to the start tab, see anything fishy?
    Uncheck everything, restart the computer, try Internet explorer again.
    Nothing needs to start with the computer, you can start anything you need when you need it.
    cwerdna and PriusGuy32 like this.
  3. Mendel Leisk
    42,361
    Did a general check for updates, Java popped up an update dialogue, I told it to check for updates, it said I was up to date, closed it, IE started working again. So there you go. Microsoft assistant was pretty much useless: most of the fixes required running IE...
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Chrome. FTW.
    xliderider, cwerdna and PriusGuy32 like this.
  5. Former Member 68813
    3,524
    983
    US
    Agree, Chrome or Firefox is the way to go. If PC starts to act up, time to scan for viruses or hard drive bad clusters.
    cwerdna likes this.
  6. frodoz737
    frodoz737 Top Wrench
    4,808
    2,562
    33
    Unfortunately Explorer is required at times for some of us. Mendel if you must have it, in addition to Chrome and/or Firefox, roll back it back to Explorer 10 and set Google as your default search engine as Bing is good for nothing. Also...bump your security when in use. Hope this helps.
  7. Mendel Leisk
    42,361
    It was apparently something with Java, working now.
  8. frodoz737
    4,808
    2,562
    33
    ;) Understand.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I stopped using IE the last time PC got updated. A few other sites weren't working quite right either. I asked my friend about it and he said that it's because IE is interpreting HTML correctly. Firefox and Chrome are proliferating the use of sloppy HTML. All I know is all my websites work with Chrome, so I switched.
  10. frodoz737
    4,808
    2,562
    33
    I only use Explorer to connect to work server and load some drivers. I find Chrome best for daily usage. Mozilla/Firefox used to be good, but find my security works overtime while on their servers in the last few. YMMV
  11. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    A bit early for April Fools
    bwilson4web, fuzzy1 and ftl like this.
  12. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Re: Java (presumably Oracle, formerly Sun), is there some reason why you have it installed?
    Unless you have something that requires the JRE (Java Runtime Environment) or JDK (Java Development Kit) (see Java SE - Downloads | Oracle Technology Network | Oracle), I'd uninstall it from Programs and Features.
    If you must have it installed for some reason (e.g. you run something that requires the Java VM or you do Java development), unless you often visit sites that for some reason require Java (NOT Javascript!!!) in the browser, I'd disable it in browsers via Control Panel > Java > Security. Uncheck Enable Java content in the browser.
    It seems Oracle's Java VM has tons of security holes and is often targeted. If you have no reason for an increased attack surface, disable it in browsers or remove it.
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    "Awesome" communique.
    Don't call us. We'll call you.
    If we feel like it.
    And LOL that you use Windows.
    #13 SageBrush, Feb 23, 2015
  14. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Hey... I'm a PC guy. I use Windows at home and it's fine. Started w/PCs w/DOS 2.0 (which added support for directories and hard drives (aka "rigid disks" in IBM speak back then), LOL). Back then the PC XT had just come out and came with a 10 MB hard drive.
    At work, I use a Mac but my work is mostly a Mac shop. It's ok. I did Mac software QA for a living for 4 years (at a company that's a predominately a Windows shop), so I'm plenty used to the Mac.
  15. Mendel Leisk
    42,361
    It's weird, yesterday it was enabled, without any intervention by me. In the throes of trying to resolve the IE problem, trying various things, ome Oracle dialogue popped up about updating, I clicked sure, and it responded that it was up to date.
    This morning it was disabled, again without any action on my part.
    One irritant I have with Windows 7, in general, is the decision to HIDE the pull down menus (to get to add-on management), in most programs. I know the secret hand shake (ALT key) to temporarily display them, but it's basically a pain.
    Thanks for the specific to my problem feedback, btw. I don't mind the "why don't you switch browsers/operating system" comments, but...
  16. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    Internet Explorer
    When you WANT to be on miserable users all the time
    #16 Chuck., Feb 24, 2015
    bwilson4web likes this.
  17. ETC(SS)
    7,571
    I have to use IE at work, and I'll admit that Chrome, Safari (which I'm also forced to use) and FF are all just about equally aggravating.
    Except for Chrome, my posts here are just about equally divided between them.
    My IE is behind an intranet and VPN, so it's working about as poorly as it usually does.
    I haven't noticed anything unusual lately.
  18. Mendel Leisk
    42,361
    I like the bookmark setup in IE, it's the devil I know. Use Firefox once in a while, mainly for more security with dodgy sites.
