Interpeting OBD "Help"
Discussion in 'Gen 2 Prius Technical Discussion' started by tkc100, Jun 28, 2024.
  1. tkc100
    tkc100 Member
    92
    25
    Arizona
    I do not know whether to post this as a fuel economy issue or as a technical issue.
    The problem is poor fuel economy, but the solution is technical, at least to me.
    I am working with my 2007 Prius which is getting very poor mileage. This is the 4th Prius I have owned, so I kind of know what to expect as far as mileage. However, this is the first one that I have had the opportunity to work on. The others were lower mileage new cars and all I ever had done to them was to change the oil, filters and tires. Now I am a 71 year old, with more time than money. Actually, I have always enjoyed working on my own cars but this one is a real challenge. It's a computer on four wheels and the learning curve is steep.
    I worked as a mechanic for 15 some years but it was before OBD. All of the numbers and abbreviations have kind of dazed my mind.
    If you would take the time to look at the attached files and give me your input, I would greatly appreciated it. The two files are the same, just in two different formats. The Excel file has the top row frozen so it is a bit easier to work with.
    I also have a concern for the CAT temperature. Way back when. When I was working on cars the CAT would overheat if the fuel mixture going into it was too rich. It's the first time I have ever seen actual temperatures though and have no idea what is normal. I read somewhere that the outlet temperature should be higher than the inlet.
    Meg&Bear likes this.
  2. Leadfoot J. McCoalroller
    8,289
    7,803
    Pennsylvania
    2018 Prius c
    Do you know much about the condition of the hybrid battery?
    I think I'm seeing pretty normal numbers as far as the data given- the gas engine seems to be running fine.
    That makes me wonder if the hybrid battery is getting weak, and is therefore less available to help out when you push the skinny pedal. The computer normally solves this problem in real time by forcing the gas engine to shoulder more of the load, which means reduced MPG.
    Although sometimes hybrid batteries last longer, 16+ years in a hot climate is a pretty good run.
  3. Brian1954
    Brian1954 Senior Member
    2,687
    1,073
    South Central PA, USA
    ^^^ +1
    Additional questions.
    1. How many miles on the car?
    2. Do you know the past history of the hybrid battery?
    3. What gas mileage are you getting?
    4. What type of driving? City, highway, mixed?
    In all likely hood, the hybrid battery is weak.
  4. tkc100
    tkc100 Member
    92
    25
    Arizona
    136,000 miles + -
    The hybrid battery was replaced with a new not recondition battery 18 months ago.
    Dr. Prius battery life expectancy test 97.6 %. I think I am calling this test my its proper name. The test take about 10 minutes and puts a sustained load on the battery. I am still learning how to interpret the main display page.
    According to the MFD 32 to 36 MPG However when I look at the display showing the bar graph it sometimes shows 40 or so MPG.
    Using the M/G = MPG on the last tank full of gas 32.6 MPG. There was some sustained idle time while I was getting educated on OBD adapter and the associated apps.
    The data I provided was from a 23 minute test drive of both city and highway driving. Refer to the vehicle speed column. Data samples at 10 second intervals.
    I know that the EPA's and manufacture's claims are seldom if ever achieved but I can't remember ever getting less than 40 MPG with mixed driving conditions in my previous Priuses.
    The loss of fuel economy is one thing but I do not what to damage the engine or any of its components. Namely the CAT
  5. tkc100
    tkc100 Member
    92
    25
    Arizona
    I was also wondering if I was interpreting the data provided correctly. (Lean, Rich & Voltage)
    Fuel Trim is a %. % of what?
  6. Brian1954
    2,687
    1,073
    Are you in Arizona? AC usage will reduce gas mileage.
    It looks like the ICE is working fine. Wait until you have four full tanks of fuel, them calculate the fuel mileage.
  7. Tombukt2
    Tombukt2 Senior Member
    13,863
    2,519
    Durham NC
    Just use what you're taking out and putting in these cars should almost go 400 420 mi until you're flashing light is on. Then you have about 30 mi to find gas or be sitting there looking right silly and then at that time you should be putting in about 10 gallons of fuel 10.1 10.3 I got an '09 telling me I'm getting 37.9 mi to the gallon but by the filling up and figuring out what I've taken out and all that I'm getting 40 something oh well that's about right to the above scenario driving works out and all of my generation twos which are three right now I think and it works out to be about the same some of them at different mileages or a different places on the gauges for whatever reason that doesn't matter I know I have one or two that take 300 miles to get to a half a tank and then from half a tank to a quarter is almost seemingly instantaneous and so on but at by the time the flashing pip is flashing we're sitting at 400 mi 420 somewhere in there like clockwork and all of them that I've had so far.
  8. Leadfoot J. McCoalroller
    8,289
    7,803
    Pennsylvania
    2018 Prius c
    Sounds like it's safe to rule out a tired battery- a new Toyota unit is as good as it gets.
    A/C certainly causes more fuel to be burnt, but if you've been living in Arizona for a while I'll guess you used A/C the whole time.
    A measurement error as Tombuk2 suggests could do it- worth comparing the dash display to a real calculation.
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    When the engineers test the powertrain, they figure out what is needed (fuel, ignition advance, etc) to achieve their goals (hp, emissions, mpg). Those values are programmed into the ECM.
    As the engine runs, the ECM looks at several sensors (RPM, Mass Airflow, temperature, etc) to determine base fuel injector on time for that particular moment. After combustion, the Air Fuel Ratio sensor (located in the exhaust manifold) produces a signal that indicates the resulting AFR.
    If the engine achieved the target AFR (fuel mixture), then nothing is changed for the next injection cycle. If the AFR was "lean", then Fuel Trim makes a positive correction to add fuel. If "rich", then a negative correction to reduce fuel.
    So the "%" is a percentage of the current injector base on time. "Zero percent" is basically no correction, as it left the factory, and "everything's perfect".
    Short Term Fuel Trim is a reaction to the AF sensor. If STFT moves "too far" away from zero, Long Term FT steps in. LTFT is a learned correction that's stored in memory for a given range of "RPM x load " values. STFT plus LTFT gives you the total correction value.
    0 +/- 5% is "perfect". Up to 10% is fine. 15% means something's not right. Above 20% will set codes.
    Catalytic converter temperature could be an algorithm that's based on operating conditions. Or it's inferred by monitoring the amperage of the A/F and O2 sensor heaters. As the sensor temperature goes up, heater resistance increases, so electrical current goes down.
    That said, I have never paid much attention to converter temperatures. Fuel trims and (a lack of) engine misfires are more important for converter health.
    MPG has a bunch of things that can affect it. Tire type (low rolling resistance )& inflation, exhaust restrictions, HV battery condition, missing areo body panels, 12V battery condition, general engine "health" (compression, cam timing), etc.
    Meg&Bear and Brian1954 like this.
  10. tkc100
    tkc100 Member
    92
    25
    Arizona
    Thank you all for taking the time to assist me.
    mr_guy_mann you are very good at explaining things and thanks to you I now have a much better understanding of fuel trim.
    I never considered the fact that by measuring the amperage draw / resistance of the sensors upstream and downstream it would be possible to infer the temperature of the CAT.
    I do however have one additional question.
    "0 +/- 5% is "perfect". Up to 10% is fine. 15% means something's not right. Above 20% will set codes."
    Are these figures based upon the total fuel trim (+ -) or just any movement + or - either side of 0?
  11. mr_guy_mann
    4,118
    2,014
    NJ-USA
    "It depends".
    Fuel trims are additive. (+10%) ST + (-5%) LT = +5% total.
    STFT will move around a bunch as you drive. It can vary a percent or two at steady state conditions, but that can be on either side of 0. It can do weird things on decel. Or not. Depends on what the engineers decided to do.
    LTFT is a better indicator of trends over time. If something doesn't happen long enough to affect LT then I won't pay too much attention to it - most of the time.
    If I have a problem, then I look at STFT.
  12. tkc100
    tkc100 Member
    92
    25
    Arizona
    mr_guy_mann
    I was looking at it wrong. I thought the 10% was movement on a scale or absolute values.
    With your example I thought it would look like this. (+10% STFT + -5% LTFT = 15
    As you suggested Fuel trims are additive. (+10%) ST + (-5%) LT = +5% total makes perfect sense.
    Even doing it in error I didn't have any values over 10 so I guess my little ICE is working pretty well at least as far as fuel management goes.
    Tell me if you can where does a person go to find authoritative reference material relating to the Prius?
    Where do Toyota technicians to get trained or access training material.
    I have a version of the shop manual in a PDF format for my 2007 but does not explain the theory of operations.
    Years ago when I worked for GM and Mercedes-Benz they both had a plethora of training materials and this was before the internet.
    They were not always easy to access, especially if you were not within the corporate circle but with perseverance and some gentile persuasion they could be obtained.
    Forums such this and individuals like you are a valuable source of information but let say, I want to learn about the Prius fuel management system. From the air going in to the exhaust going out. Or the steering or the braking systems. In reference to what we have been discussing. Is sensor 1 a wide range sensor, what are the voltage parameters, is it the sensor responsible for STFT........ A Prius has four wheels, burns gas and goes down the road but it does it in a manner that is very different than the cars I was trained on. I think you can see where I am going. Any suggestions.
  13. mr_guy_mann
    4,118
    2,014
    NJ-USA
    Well, Chapman keeps pointing to the "2004 Toyota Prius new car features". It's a lengthy publication that covers much of the theory and operation of the Gen2 Prius. Apparently the only source is to get a short term subscription to Toyota TIS and download it from there.
  14. ChapmanF
    19,025
    Our wiki page Toyota Service Information and Where To Find It | PriusChat does a good job explaining all that.
    Yes, the New Car Features manual is the "missing volume zero" of the repair manual, the one that explains the whys and hows of all of the whats the later volumes talk about.
    But at TIS you find more than just that. There's a whole separate tab of Quick Technical Guides on all sorts of topics, and up at the top is a Technical Library tab that gets you into all of the "University of Toyota" course materials used in training their technicians.
    The wiki page tells you about all of that.
  15. tkc100
    tkc100 Member
    92
    25
    Arizona
    I have been sick for the past few days and that is the reason I had fallen silent.
    Thank you for pointing me in a direction where I might get detailed and specific information on my Prius
    After I pay for a subscription to the TIS can the material be downloaded?
  16. Tombukt2
    13,863
    2,519
    Durham NC
    Thank goodness when the dream was conceived back in 1994 and shown at Tokyo. Most of the engineers and designers were still for the most part Toyota people. There was a lot of input from other sources including companies in America but still it seems that 2010 is when all the hubbubs started and was executed very well specifically for the western markets it seems like and things took a turn for what this person says is for the worse. When things kind of went a little bit south for the Prius of course they had become popular and people in the know I guess came to expect certain things like they did from Corolla and other Toyota vehicles and apparently they were seeing a trend trending kind of downward and away from that certainly what I saw with the generation 3 but with the two and the original which is pretty much the same as the two they had something and then they didn't That's just my take on it. That's why people that seemingly are in the know of the car business kind of stick with the generation too and will work on the others because of their money makers if you will. The generation 2 I guess is not because it's really like a regular car for the most part the one and z engine and all of that other than the CVT with the electric motors and some cabling and a battery everything was pretty much as normal Toyota. Which is a keeper.
