Intro and routine maintenance BoNaNzA! (pic heavy)
Discussion in 'Gen 2 Prius Main Forum' started by jbeebe, Aug 7, 2019.
  1. jbeebe
    jbeebe Junior Member
    PA
    Hi everyone,
    I wanted to thank you all for this excellent online community. I am a heavy user of "forums" when it comes to auto and motorcycle maintenance, so I appreciate buying a car with a large community support system.
    I'm switching careers and decided to go to law school part time in the evenings. This will increase my daily commute to 1.5-2hrs (mostly highway). Spending this much time on the road necessitates a tool for the purpose! What I love about tools is that while some are very generic, such as a hammer, some are very specific in use. A brake piston compressor, for example. The Prius is a very specific tool, and I love it for that. It is extremely good at one thing....conserving fuel. Sure, with the back seats down it can hold a bunch, but not as much as my 4Runner. Sure, it's somewhat comfortable and quiet, but not as much as my wife's Lexus. Can it hold a 2x4x8? Maybe, but not as easily as my full-size bed 93 F150. But fuel efficiency? Heck, my motorcycles can't come close. My previous daily driver is a 2000 4Runner and my wife drives a 2006 Lexus IS250, so you can see why we went with a Toyota.
    Okay, on to the pics! I found a 2006 1-owner Prius outside of D.C. with 145k miles. It is the trim package 8 which I believe had the most available options.
    As you can see, after my detailing it is clean and solid. I'm disappointed that the PO didn't choose a body shop worth salt though, as the paint and panels in a few areas are pretty poorly repaired from some previous damage.
    Because of my soon-to-be lack of free time, I decided to spearhead any maintenance that may arise. After searching this forum for a week or so I compiled a list and the parts and did a pretty exhaustive amount of preventive and necessary maintenance on it. Although some parts weren't showing signs of failure, I don't want any common issues to poke their heads within the next several years so I took the initiative. It took me the better part of a day with a few breaks (i'm experienced mechanically). Here's a quick list before the pictures:
    - oil change with fumoto valve
    - transmission fluid change
    - both coolant systems fluid change
    - ICE water pump and gasket
    - inverter coolant pump
    - coolant valve
    - spark plugs
    - pcv valve
    - serpentine belt
    - air filter
    - cabin air filter
    - tail light assembly
    - restore headlight clarity
    - wheel trim ring replacemen and locking lug nut removal
    First was a simple oil change, but then I installed the first "mod" I do to each car I buy; a Fumoto oil drain valve:
    Next was to replace the transmission fluid with toyota atf ws. I used a transfer hand-pump to fill and it's super easy. I just use the cheap ones and replace them when I don't feel like cleaning it: Multi-Use Transfer Pump
    I then replaced the spark plugs with oem NGK's:
    and while I was in there replaced the pcv valve as well with a toyota part:
    Next I drained both coolant systems:
    and replaced the ICE's water pump and gasket with a toyota part, also replacing the serpentine belt while having the old one removed. I considered replacing the idler pulley while I had it off, but if it starts to bind up in the future it will only be 10min to replace, so I decided against it:
    Next came time to replace the inverter pump and valve. There was an intermittent P1116 & P1121, so I decided to replace both the valve and pump with toyota parts. I used the well-documented "headlight removal method" for this and it went smoothly and easily with no need for bottom access or for cable-type hose-clamp pliers.
    First the pump:
    and then the valve right next door:
    Then all buttoned up:
    I used an Airlift vacuum tool to refill the coolant systems and then bled the system accordingly using Toyota Super High Mileage 50/50.
    Next was to replace the taillight assembly that was in poor shape with a perfect condition used one off ebay:
    I also replaced the air filter, cabin air filter, and wheel trim rings (pack of 4 off amazon), discarded the locking lug-nuts, replaced the windshield wipers, and restored both the drivers side headlight while it was off and my wife's headlights:
    A little action of my wife's car getting the headlight treatment:
    I clear-coated the headlights with an aerosol 2K clear-coat after using a 3M restoration kit (the type that uses a drill pad)
    So there you go, not a bad day's work! Thank you again for this wonderful online community. On the highway i'm averaging 51mpg, so i'm pleased!
    #1 jbeebe, Aug 7, 2019
  2. ski.dive
    ski.dive Active Member
    967
    246
    Hutchinson Island,FL. Mt. Snow,VT
    AWESOME WORK!! = Now your ready for another 145k miles!!!
  3. jbeebe
    PA
    Thank you, that's the hope!
  4. ski.dive
    967
    246
    How much did you pay for your Prius??
  5. jbeebe
    PA
    I paid $4300. 145k miles, one-owner, good service history, bought private-party. A little high in my opinion, but I was willing to pay the extra few hundred bucks for the background knowledge of where the car came from and it's service history.
  6. ski.dive
    967
    246
    If I was to buy a used car, I would only buy a one owner used car:)
  7. lech auto air conditionin
    830
    606
    261
    san francisco
    Highly recommend to completely drain and properly recharge the air conditioning if it has never been done it’s way past due . Problem is finding somebody to do it correctly . Because sometimes it’s the shops that causes the problems after an AC service . but the Prius air-conditioning refrigerant level if it is low can reduce your gas mileage when in use and both shorten the life of the air conditioning compressor and the HV battery because it’s always pumping more and more power to keep the air conditioning compressor spinning faster to compensate for a low refrigerant charge .
