Introducing the 2016 Chevy Volt (2.0)
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by F8L, Jan 12, 2015.
  1. bisco
    52,838
    justin's funny, i'm just the straight man.
    F8L likes this.
  2. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    Thanks. If they want ehr all they had to do is buy the denso parts for cooled egr/ehr used in the camry hybrid and prius c. Cooled egr is the more complicated part. I look forward to seeing bsfc curves and real world mpg.
  3. Trollbait
    12,822
    GMs have an oil life monitoring system that goes way beyond a simple odometer timer. From lab testing, the engineers know the consumption rates of common oil additives in the engine under a range of conditions. From that data, the car's computer can calculate a percent life left to the oil from the engine's operation. For those that perform used oil analysis, the system results tends to be close to the chemical tests prediciton. The cars I had with it went around 7500 miles between changes. In a mild climate, with light cruising, going over 10k miles isn't unheard of.
    And why does this feel like I just typed out a similar post not too long ago?
    F8L likes this.
    52,838
    sorry, 10,000 hv miles, or overall? and what if you don't do 10k in a year, do they recommend time?
  5. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  6. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    Pretty sure they do time. My car said it's time for an oil change right around 2 years and there were less than 5k miles on the engine. I think at 2 years it recommends a change no matter what.
    austingreen and bisco like this.
  7. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    The oil life calculation is a combination of engine usage and a 2 year max time interval.
    I drive too much so I got caught by the engine use rather than time. It seemed equivalent to about 15000 to 18000 miles max.
    #127 Jeff N, Jan 13, 2015
  8. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    There are two ways of viewing that statement
    Viewpoint 1: Yes, only 1% of the US driving population would have the Volt as the best fit for their needs.
    Viewpoint 2: A niche market of 1% of 220 million vehicles is 2.2 million vehicles. That is one heck of a niche. Well worth pursuing.
    Trollbait, F8L and Jeff N like this.
  9. austingreen
    13,714
    4,232
    Austin, TX, USA
    Yep. US market is about 16 million per year. If the volt's niche (can fit in a 2+2, drives less than 50 miles a day typically, has a garage with electricity, doesn't need to haul or tow in this vehicle, has money, likes this type of car) is 5% and the volt could get 1% that is 160,000 a year close to the the peak of the prius (181,222 in 2007). It could happenin 5 years with the gen III, I don't think this one is that good, but a good oil shock we could get to 100,000 ;-)
    F8L likes this.
  10. Tideland Prius
    16,678
    I'm sorry, what? That doesn't change the subject. You're avoiding argument that the Prius had similar changes going to the 3rd gen as we're seeing here on the Volt.
    Notice the Prius still runs on 15" wheels? That too is a factor which could increase appeal.
    The red looks a LOT better than the blue!! More mature, less boy-racer.
    • electric water pump
    • aerodynamic enhancements (vortex generations, aero corners, flat underbody with air management system, rear underbody fins)
    • wide cargo area with fold-flat seats (I think the 1G does but nothing's been mentioned about the 2G)
    Toyota is pretty hardcore on the fuel efficiency and emissions mission of the Prius which probably explains why it insists on 15" alloys as standard equipment. That usually isn't a problem. The problem is when it decided to offer 17" alloys, which means larger wheel wells, which visually make the 15" alloys small. The Gen 1 was designed for just the 14" alloys and therefore it looks proportional. Same goes for the Volt 2.0.
  11. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I've never heard of a showroom for a lease...but have "heard of" such a thing for a one-night rental.
    Mike
    F8L likes this.
  12. bisco
    52,838
    LOL, i'm into long term investments, 'buy and hold' as it were.:p
    F8L likes this.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I'm straight and I think you're funny too. :)
    I think I changed my oil around 25k miles but I don't really remember. My oil life is currently at 56% at 40,211 total miles. Which makes sense I think. I have approx. 13,000 engine miles and 27, 231 EV miles.
  14. bisco
    52,838
    that's pretty sweet! i've used up my two free oil changes. hmm, maybe i'll wait two years, i only have 8,000 hv miles.
    F8L likes this.
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Well that's 2 more oil changes you avoided. :)
  16. bisco
    52,838
    i owe you a hundred bucks!:)
    F8L likes this.
  17. Sergiospl
    3,938
    1,351
    28
    Not a day trader for quick hit and run profits, Gold or Silver.
    F8L likes this.
  18. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    When most car buyers have 20 - $25k to spend, they go buy an Accord LX or Sport, Camry SE or Altima, etc ... When they're looking at something the size of a Corolla or Civic, they expect to pay under $20k. Volt 2.0 at $33k plus credits ... 25k units per year sold in US
    At $4 gas, Accord Hybrid saves merely 4.4 cents per mile over an EX Whoopee. And most buy the cheaper LXs anyway
    Need Gen 4 to help boost hybrid numbers.
  19. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Yep.
    It DOES buy owner convenience. I pickup juice 2x as fast at public and workplace charging. I can start charge much later and still get to full w/o hogging the stations (many folks will have gone home already or finished charging).
    L2 is already kinda slow (when trying to opportunity charge or go on a long trip)... even w/a 6 kW OBC, esp. compared to 44+ kW DC fast charging. Nissan Quick Charger - CHAdeMO DC Fast Charging for Electric Vehicles is 44 kW. Tesla Superchargers I hear have output of 90 kW to 120 kW, to individual cars.
    As I posted elsewhere (my daily driver is a '13 Leaf SV):
    When people TRY to use them as BEVs (like at my work and amongst some Volt friends of mine) and utilize L2 30 amp workplace and/or public charging, it DOES matter.
    At my work, besides our EV valets (which have only easy access to 6 J1772 handles dedicated to them), we have 8 self-service J1772 handles, 4 Tesla HPWCs and a couple 120 volt outlets. I haven't counted recently, but I know we're north of 50+ EVs/PHEVs. For people who go home earlier, it DOES matter how quickly the spots can be turned over. And, for me, see my use case. I like being able to start late and achieve 80+% charge. 80% no prob. 100% including the bounces at the end? Is no problem w/an almost dead Leaf w/6 kW OBC given 5 hours.
    and in another post:
    I've seen some pricing for some workplace charging (mine's free). For the ones that charge by time (assuming 30+ amp EVSEs), people w/6+ kW OBCs have a decent deal while those w/3.x kW OBCs have a not-so-good deal.
    One friend of mine (possibly at the same company as gg_got_a_tesla) w/o any EV/PHEV sent me their pricing of $1/hour for the first 5 hours and $5/hour for each additional hour. I had to explain to him the good/bad deal depending on the OBC, encouraging turnover, preventing blocked spaces, costs of charging @ home, etc.
    The pre-'16 Volt guy on a 208 volt (common commercial power) 30 amp EVSE will be paying ~$0.32/kWh. My Leaf would be paying betweeen $0.167 and $0.175/kWh.
    PriusC_Commuter and F8L like this.
  20. Species5618w
    Species5618w Member
    140
    50
    A volt owner can just leave without charging. It saves him/her a little bit of gas (or money if billed by charge time), but not time. A Volt uses 35kwh/100 miles or 2.7 gallon of gas. So that's about 13kwh/gallon. Even at 6.6kw, charging at $1/hr is a bad deal, let alone $5/hour. And that's assuming the trip home would be on gas completely. The Volt is really designed for round trip commute less than 38 miles. It's not suitable for 76 miles commute (or 100 miles for Gen 2). GM seems to believe that the vast majority of people's commutes would fit in 38 miles, which is probably true.
    Having said that, I would totally support a DC port and external chargers.
