Invalid mode vs. Battery disconnect
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jaykh, Jul 7, 2018.
  1. Mendel Leisk
    42,271
    Steps:
    1. Ensure parking brake is set..
    2. Push start button twice without foot on brake pedal. (dash display should look pretty much like if the car is fully on, aka "Ready")
    3. Depress brake pedal (not parking brake) and shift to Neutral.
    Not working?
  2. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    Yes not working
    Twice on the start button gets accessory mode right ? The dash was in accessory mode in the video (all lit up)
    Ready mode is ready to drive mode right? I don't think you want to be in ready mode
  3. Mendel Leisk
    42,271
    Yeah, I think we're just tripping up on terminology. It seems like you're in On, but the car is behaving like you're in Accessory:
    one push without brake: Accessory (basically for listening to the radio, no shifting allowed)
    two pushes without brake: On (cabin ventilation will run if it's on, dash lit up, you can shift out of Park)
    one push with brake: Ready (fully on, engine starts in a few seconds, usually)
    That last one is what you do every time you use the car. Even then, the car won't let you shift out of Park (into any other gear) if you don't have the brake pedal depressed. It also won't let you shift out of Park if you're in "Accessory", regardless of brake pedal pressed or not.
  4. Taxi/Limo
    526
    107
    Then I think I am in the On mode (two pushes without brake) dash is lit up
    I asked Nutz about boltz to help me out since he is nearby
    If I could watch someone do it successfully on my car that would help
  5. Mendel Leisk
    42,271
    Just for giggles, I gave it a try. Worked for me. It's a little hard to see, but the indicator jumps from P to N and back to P, and you can hear it too:
    #45 Mendel Leisk, Jan 27, 2020
    Raytheeagle and Grit like this.
  6. Taxi/Limo
    526
    107
    Okay Thanks
  7. Taxi/Limo
    526
    107
    I am going to try it and see will report back Thanks
  8. Taxi/Limo
    526
    107
    I pressed twice and put my foot on the brake and then shifted to N after first engaging the emergency brake and also with the energency brake unengaged.
    I got inconsistent results .. both ways e brake on or off sometimes it would go in the N sometimes it would not
    It could be my timing to slow to fast
    At any rate I think I will try and easier method using the little jumper wire in the OBD terminal
    I hope that is easier
    Thanks man
  9. Taxi/Limo
    526
    107
    Here is a method of bleeding the brakes without using invalid mode
    Does anyone have any comments on this before I attempt it ?
    Thanks
  10. ChapmanF
    18,960
    Worthless. Presenter hasn't even pretended to be interested in learning what the steps are or why.
    YouTube is a resource with a lot of good information but man it's hard to find.
  11. Mendel Leisk
    42,271
    You do have to hold the shifter at the Neutral position for a split second. E-brake on or off does not make any difference, for this operation. Yes it will, for the ultimate goal of getting into Invalid mode, to shift into to Neutral no.
    Again, make car "on" (two pushes of start button, foot not on brake.
    Set Parking brake (if it isn't already)
    Press the foot brake (not the parking brake), and push shifter to Neutral, and hold it there a split second.
    What happens?
  12. Taxi/Limo
    526
    107
    It goes into neutral but not consistently
    Do you have any experience using the jumper in the OBD2?
    Thanks
    #52 Taxi/Limo, Feb 2, 2020
  13. Mendel Leisk
    42,271
  14. ChapmanF
    18,960
    The jumper lets you do two things:
    1. it lets you read trouble codes from most of the car's computers, by counting the blinks of the dash lights, if you are getting warnings and don't have a code scanner handy.
    2. It lets you clear some trouble codes, in case you have some and you know why and you fixed the problem and want the codes to go away. Brake codes, for example, can be cleared with 8 pedal strokes within 5 seconds, as you saw in the video (only I don't think the presenter got those in within 5 seconds, seemed to have never looked up the details).
    (1) is the most important use of it, though people talk about (2) all the time as though blindly clearing codes were some kind of good idea.
    It doesn't do anything to activate the necessary valve sequences for bleeding. It does nothing for bleeding at all. It is for reading codes and clearing them. Its one use for you would be if you managed to set some trouble codes during your bleeding attempt, it would let you clear them.
  15. Mendel Leisk
    42,271
    Something very simple must be tripping you up.
    The car is "on" (two pushes of start button without foot on brake).
    Foot on brake, push shift lever to N, and hold it there.
    Car should shift to Neutral, in a second at most, reliably.
  16. Taxi/Limo
    526
    107
    I could be doing something sightly wrong but I don.t know, or there could be something about my car that is not right
    Seems the jumper method is a lot less complicated just not sure if it works
  17. ChapmanF
    18,960
    Too bad there's no place to get information about that.
  18. Mendel Leisk
    42,271
    Maybe look on achieving Invalid Mode as a necessary hurdle. If you can't manage that, might be safest to shell out the C note and let the dealership do the deed. ;)
    FWIW, I was near-flummoxed by not having parking brake set, last time around.
    Raytheeagle likes this.
  19. Taxi/Limo
    526
    107
    I have decided to have a highly recommended mechanic do the brake bleed
    I am going to post this question separately here on Gen 3 maintenance and TS
    How can I know if this mechanic (first time with him) does a good job?
    Since I won't be there to watch
    Thanks
  20. ChapmanF
    18,960
    Little video cameras are cheap.
    Some TV news orgs have done exposés of quick-lube places where they go in and ask for the work to be done, and leave a car with little cameras hidden all over.
