Inverter converter swap.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RajivR74, May 28, 2019.
  1. RajivR74
    RajivR74 Junior Member
    37
    Horn Lake, MS
    I'm working on a 3rd gen (2013) Prius for a friend whose inverter converter failed (code P0a94). I purchased a used inverter off ebay which the seller (and ebay's fitment guide) states will work with the 2013 Prius even though it came out of a Prius V.
    The original inverter converter has a model number G9200-47210 with the big 'K'.
    While the one I purchased on ebay from the Prius V has the model number G9200-47161 with the big 'B'.
    Would this work? Is it plug and play or is there more involved? Anything I should be worried about? Any help & input would be greatly appreciated by myself & my friend who owns the car. Thank you. 20190526_125030.jpeg CYMERA_20190526_145446.jpeg CYMERA_20190526_145554.jpeg CYMERA_20190526_145615.jpeg CYMERA_20190526_145642.jpeg CYMERA_20190526_145707.jpeg
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Curious if you happened to document the sub-code that would be displayed on the freeze frame data? I think the P0A94 has 20 or 25 sub-codes to help determine the problem. Going straight to a complete inverter swap seems like a big jump.
    Raytheeagle and RajivR74 like this.
  3. Mendel Leisk
    42,212
    Just curious: how much was the inverter you bought, say in US dollars.
    RajivR74 likes this.
  4. RajivR74
    37
    Horn Lake, MS
    Unfortunately I don't know the sub code. I used the torque app paired with a generic bluetooth OBDII reader. I know I should use Tech Stream, but I didn't have it at the time.
  5. RajivR74
    37
    Horn Lake, MS
    It was approximately $300. Which looks like it is in good condition. I'm just worried about the difference in model numbers & if it would be compatible & what issues could arise from its use.
  6. Mendel Leisk
    42,212
  7. RajivR74
    37
    Horn Lake, MS
    Unfortunately that listing is only for the housing. Not the entire inverter/converter. I found another one with the original part number but that seller offers absolutely no warranty.
  8. Mendel Leisk
    42,212
    Oh I see. Strange, a few minutes ago it was a full inverter, then when I click on it now, it's saying "ended", and (as you say), an offer for an inverter shell. So anyway, they're out there.
    I notice if I go to Toyota Dealership website, they don't offer inverter for sale, says discontinued or something? Not good. I appreciate price would be through the roof, but still, strange that it's not even available.
  9. Patrick Wong
    18,210
    6,517
    Yes, I looked at the Toyota Gulf Freeway (Houston) parts website and also could not find inverters for sale. This is very disappointing considering the 2015 is only 4 years old. Hence you will have to be scrounging on eBay and other used parts sources.
    I noticed the 2006 Highlander Hybrid battery is not available as a new part. That HiHy model was only available in 2006 and 2007, then a new HiHy design came out in 2008. Again, the need to scrounge for a used part or "remanufactured" when that battery dies. Hey, at least you can still buy a new inverter - priced at $6K...
    Regarding the OP's query about fitting a Prius V inverter, my suggestion would be to review the electrical wiring diagrams from that model and the Prius. See if there are any differences with respect to electrical connector pin assignments, and whether the connectors appear physically the same. If there are no differences then maybe it might work, but you would still have a concern about whether the inverters have different electrical properties, like whether a command from the hybrid vehicle ECU requesting a certain level of motor generator (MG) power results in differences regarding the inverter voltage produced to feed the MG, whether the inverters contain firmware differences, etc.
    #9 Patrick Wong, May 31, 2019
    mjoo and Mendel Leisk like this.
  10. Mendel Leisk
    42,212
    I vaguely remember there was some law on the books, regarding manufacturer's obligation to keep replacement parts in stock. Googling, it doesn't seem there's a clear answer though. Would be interesting to see if some manufacturers are better than others...
    Paul E. Highway and Raytheeagle like this.
  11. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_O
  12. Mendel Leisk
    42,212
    @Tideland Prius just posted an article, Toyota saying within 5 years 50% of their sales will be hybrid, plug-in hybrid, or fuel cell. Something not adding up?
  13. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    When I was at a previous employer who was a supplier to Toyota, it was in our contract for 7 years after the model is changed to have the ability to supply materials. As you can imagine, this can be challenging as the usage rate declines but yet you have to maintain stock:cool:.
    But the cost of doing business :unsure:.
    RajivR74 and Mendel Leisk like this.
  14. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    The Prius V is also a larger, heavier vehicle with the benefit of additional transmission cooling applied to the electric motors. If the inverter's power command is internal to the inverter controller (and not another controller) then you could have a problem with overheating the electric motors.
  15. RajivR74
    37
    Horn Lake, MS
    Good point! I'm glad I was able to nip it in the bud. I got refunded & purchased one with the right part#. It's on its way now.
    Mendel Leisk and mjoo like this.
  16. Leadfoot J. McCoalroller
    8,255
    7,757
    Pennsylvania
    2018 Prius c
    California has a good strong state law (Song-Beverly) applicable to household consumer electronics priced over $100. Spare parts must be made available for 7 years.
    I'm not aware of any other generally-applicable law like this. As you might expect, the usual remedy isn't a spare part, it's a stonewalling defense occasionally ultimately resulting in a free replacement product (not necessarily new or identical) for the persistent complainant.
  17. Mendel Leisk
    42,212
    Sometimes it's a godsend, when parts are no longer available: similar to cars, household appliance replacement parts can be insanely expensive. Once they're not available, you can at least justify moving on, lol.
    I've twice now repaired the "clever" door latch on a microwave, that must be approaching 20 years old. The lower priced model had a very straightforward latch, but ours: you push a mechanical panel on the front, that starts a chain-reaction in the innards. One of the components uses formed plastic hinges that just don't hold up. With steel rod, bits of wood, pipe hanger strapping and screws/bolts, I've kept it going.
    RajivR74, CR94 and GrGramps like this.
  18. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    May i ask you, since you are replacing one, what is the torque specification of the inverter bolts, along with the orange wires?
  19. Farkhod
    Farkhod Junior Member
    Missouri
    Three Touring
    So I swapped gen 4 engine for regular 2015 Prius gen 3 but once when I installed engine got fault code says
    1. P0A40 Range/Performance Of Drive Motor 'A' Position Sensor Circuit
    2. P0A41 Circuit Of Drive Motor 'A' Position Sensor Is Low.
    • Then I thought there is issue with inverter could be I had spare from the Prius V 2014’s inverter but it won’t disappear fault code pops up
    • P0A09/ Low Input Of Direct Current (DC)-Direct Current (DC) Converter State'Circuit
      P0A0D Inter-Lock Circuit Of High Voltage System Is High.
      U0110 Lost Communication with Drive Motor Control Module 'A'
    • Please advice what am I should do or how I can reach with you
    #19 Farkhod, Nov 22, 2025
