Inverter Coolant Pump Speed Signal
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Aftab Ak, May 22, 2018.
  1. Aftab Ak
    Aftab Ak Junior Member
    46
    Pakistan
    Thanks bro, can you share the inverter pump picture please
    52,899
    i can't, but perhaps someone else can.
    Aftab Ak likes this.
  3. Aftab Ak
    46
    Pakistan
    Well today i replaced my engine water pump as suggested by the mechanic, but the problem still persists (Check light and yellow warning light is ON, the car stops when get overheated, then starts after 2 or 3 minutes), now the mechanic says that inverter water pump is also to be replaced. he said that the code P314A (Inverter Coolant Pump Speed Signal) refers to both the engine coolant pump and the inverter water pump which i think makes no sense.
    Need suggestions now how to proceed, (if inverter pump is also replaced, will my car get fine??)
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Since the code is set for the inverter coolant pump, replacement of the pump could fix it;).
    But are there any other codes:whistle:?
    Remember there are 2 coolant loops so one is not dependent on another;).
    I would ask the mechanic for the print out of the codes, then post them up here :).
    Are there any other mechanics in your area?
    Keep us posted (y).
  5. Aftab Ak
    46
    Pakistan
    No other codes just P314A (Inverter Coolant Pump Speed Signal), so need to replace inverter pump now, no other good mechanics this one is a bit reliable and only deals in Prius.
    If i am not wrong i need to replace this thing? pic attached
  6. bisco
    52,899
    if there was no movement in the reservoir, it needs replacing. whether the engine coolant pump needed replacing, i can't say. are there any other issues? we won't know until you have replaced the inverter pump.
    Aftab Ak and Raytheeagle like this.
  7. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Here’s a picture of the inverter coolant pump on my 2010 Prius with the part number:
    Cross reference your part number to make sure you get the right one;).
    Good luck and keep us posted (y).
  8. ChapmanF
    19,060
    Awesome.
    Replace the inverter pump and the mechanic. In either order.
    -Chap
  9. Aftab Ak
    46
    Pakistan
    Inverter pump will be replaced day after tomorrow, then will see how the system responds. No other codes apart from p314a so far.
    Raytheeagle and bisco like this.
  10. Aftab Ak
    46
    Pakistan
  11. Aftab Ak
    46
    Pakistan
    Oka
    okay great
  12. Aftab Ak
    46
    Pakistan
    (y)(y)
  13. Chuba
    Chuba Junior Member
    45
    Nigeria
    The mechanic is trying to tell u that there is issue with your inverter coolant pump but u assumed he saying engine coolant pump.
    The code he gave u has to do with inverter coolant pump.
