Inverter coolant refill procedure?
Discussion in 'Generation 1 Prius Discussion' started by Itsmeonprius, Jul 10, 2018.
  1. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    So I'm due to install a new engine (new to me) with the transaxle so I'll need to refill the inverter coolant as part of this process. I believe the Techstream software has to assist with the refill so has anybody done this and if yes, any hints or tips or a link to a write-up?
  2. ChapmanF
    18,768
    You might check this post. A key insight for gen 1 is that one of those two "bleed" valves is on the suction side of the pump and will draw air in when opened, if you're not careful.
    No particular need for techstream. The gen 1 pump runs whenever the key's on.
    -Chap
  3. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    You don't need Techstream to fill the inverter coolant system And there are Youtube videos and other writeups to get you thru the burping. Good luck with getting the newer engine in. Kinda fascinated.
  4. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    I always use a vacuum pump to pull it in a vacuum. If it holds, I just open a valve and it fills itself with no air bubbles.
    Brian in Tucson likes this.
  5. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    I don't do mine very often, but a vacuum filler is a nice tool to have.
  6. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Brilliant thank you.
  7. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    The left fitting is the suck one, the right is the spew one.
  8. ChapmanF
    18,768
    That's right, if you're standing in front of the hood looking back at the car—but that's the opposite of the way 'left' and 'right' are used throughout the Repair Manual, etc., where they always mean 'left' and 'right' when facing the way the car is facing (that is, with the same meaning as 'port' and 'starboard', but I guess they didn't want to make the car sound like a boat).
    I called them "the nearer to the side of the car" (spew) and "the one nearer the center" (suck) to avoid any such confusion.
    -Chap
    Merkey likes this.
