Inverter Coolant Reservoir Cap Gasket.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by jzchen, Nov 29, 2019.
  1. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    I see a crack on the o-ring gasket, but can only find a complete cap. Does anyone know of a proper gasket replacement?
    Worse comes to worse I buy a completely new cap and then try to source a gasket. Then I'll come back to report what fits.
    Thanks in advance!
    moto g(7) power ?
  2. Elektroingenieur
    2,515
    3,259
    Three Touring
    Parts catalog Figure 84-32, Inverter Cooling, shows only the cap (16475-28140) and reservoir assembly. The O-ring isn’t sold separately, but from the photos in this eBay listing, it appears to be included with the cap.
    I imagine you could find an O-ring of similar size in McMaster-Carr’s catalog, or perhaps even in a bargain-basement assortment, but I’m not sure I’d use a substitute without knowing the material compatibility requirements. (Do you know what, if anything, Toyota coolant does to Buna-N, or vice versa? I don’t.)
    jzchen likes this.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    #3 The Critic, Nov 30, 2019
    Raytheeagle and jzchen like this.
  4. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Upon research the cap is the exact same for the engine coolant reservoir. Also there are aftermarket options at the brick and mortar stores like AutoZone. I almost got one there then bought instead three different packs of o-rings. I didn't know Harbor Freight has packs of them. A big thank you to both of you for the links! There's an option to select ethylene glycol compatible in the McMaster-Carr's catalog which is nice. Last time I needed one for our Sienna I ended up getting a bunch from Grainger. I don't have the luxury to order and wait I fit one that was closest from a Dorman 80000 package, eyeballing it it looked like an exact match, but felt a little loose compared to the engine coolant cap I took to compare by twisting it on. The 020-433 metric set did not have one that was a good fit, and I did not open the 020-434 standard size kit...
    moto g(7) power ?
    Elektroingenieur likes this.
  5. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Did I mention the cap was available through parts.toyota.com from a dealer for $19.xx, but the local dealer I called wanted a whopping $39.xx for the cap....
    moto g(7) power ?
  6. Elektroingenieur
    2,515
    3,259
    Three Touring
    The list price in Japan is ¥1200, or about $11 at today’s exchange rate.
    jzchen likes this.
  7. Mendel Leisk
    38,733
    jzchen likes this.
  8. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,173
    2,213
    Taylors, SC
    Over the years, I just added one on as an item that I might need in the future and just purchased a couple, when I ordered a large number of items like the spin on filter conversion kit from McGeorge Toyota.
    So, I got the on line discount with basically free shipping. In the future, if I don't need it, I had the spare like a spare tire or a fire extinguisher. Then, in the end, I can easily get almost all I spent on it off of eBay.
    I sold the old cartridge filter adapter wit a spare plastic cap and filter element on eBay, so I paid about $50 for the conversion.
    Mendel Leisk and jzchen like this.
  9. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    I found in the past Toyota markup for OE parts is huge here in the US.
    Amayama is a great resource for buying rare parts online. My Scion iQ has drum brakes but I got a rear axle from them (for disc conversion) and it was much cheaper than if I were to source it locally. It came directly to my house, no tax/tariff, at least back then when I ordered it. (Thanks for reminding me about them). There was another company I had to order the really hard to find dust shields but the name is lost in my mind somehow.
    Thanks for sharing about McGeorge. I haven't tried them yet but maybe I should. Conicelli is also really competitive. Oempartstoyou.com is another one I dealt with here in San Bernardino, just far enough that their website is accessible and I was able to pick up the parts without shipping, though it is quite a distance. Thank you.
    I returned the two packages of o-rings that I didn't use and purchased a Duralast 7051 cap. While there was a casting burr, seemed a little rough on the edges, it did twist on with just the same resistance that I felt with the OE cap from the engine reservoir, so I am happy with it. I kept the old one with the Dorman ring as a spare for emergencies. The DuraLast 7051 cap is $7.99 retail, if anyone needs one....
    moto g(7) power ?
    Mendel Leisk and frodoz737 like this.
