Inverter Coolant
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusInCA, Jan 9, 2016.
  1. Spin Spinney
    Spin Spinney Junior Member
    Raleigh, NC USA
    I
    I am at the dealer for my annual oil change and multipoint inspection. My 2013 Prius is 7 years old an has 47000 mi. I was concerned about the inverter coolant level being at the low mark. The service advisor escorted me to the mechanic who explained that it should be on the low mark because the level rises. He did not top it off. I believe him. It is December and 40 degrees F. The car warmed on the 15 mile drive to the dealership. The moral is to let it be until the fluid level falls below the low mark.
  2. JC91006
    16,936
    8,647
    On a Gen3 car, it's actually a bad sign that your coolant is LOW. I would fill it up in between the low and full marks and monitor it. See if it goes low again.
    A system that is not leaking, should be at the same level as it left the factory (it shouldn't be low when it left the factory).
  3. Mendel Leisk
    42,355
    Both my inverter and engine coolant levels very SLOWLY dropped, reached low lines, maybe around 50k kms. I topped both up and they’ve held steady since.
  4. kamrul
    kamrul Junior Member
    99
    17
    Bangladesh
    how much coolant do we need for both chambers - engine and inverter? In my area, it comes in one size only - 3.785 L
  5. JC91006
    16,936
    8,647
    get 3 of those bottles 3.785L
  6. Mendel Leisk
    42,355
    Answered here:
    Coolant change | PriusChat
    kamrul likes this.
