Inverter Cooler Pump — Aftermarket?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fivel, Jul 16, 2021.
  1. Fivel
    Fivel Junior Member
    New York City
    Hi All,
    Looking for informed perspectives on whether an aftermarket inverter cooler pump is an acceptable option. OEM is ~$120, aftermarket can be had for ~$30, so it seems at least worth considering. The only thread I've found on the issue is this one.
    (Mine hasn't failed at the moment, but I'm just over 100,000 miles, so planning out some of the 100K maintenance tasks recommended around the forums.)
    Thanks, as always.
  2. JC91006
    16,482
    8,400
    Do not replace an OEM pump with an aftermarket, especially when the OEM one is still working. There was a recall on this pump from Toyota, so your pump should not have 100k miles on it.
    Buying an aftermarket $30 pump is like playing craps in Vegas. You don't really know the company that made the pump, you can get something decent or something that's completely shit. No real winner. $90 difference, a drop in the bucket nowadays with inflation costs for everything else
    Raytheeagle and ydpplqbd like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,918
    Columbia, SC
  4. PriusCamper
    PriusCamper Senior Member
    11,105
    4,518
    Pacific Northwest, USA
    If you do your own work on your car and putting in the pump is no big deal to you then go with the $30 one. Even if you have to put another one in prematurely, you'll still be spending 1/2 as much of a price as OEM.
