Inverter cooling fan coming on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by duffasaurus, Mar 17, 2010.
  1. duffasaurus
    duffasaurus Senior Member
    177
    38
    Charlotte, NC
    I recently noticed that a cooling fan is coming on when I heard that kind of noise from the rear passenger seat area. I traced it to the vent next to the right rear passenger seat. The speed of the fan seems to increase with vehicle speed. Under what conditions does this come on since I only noticed it after driving for about twenty minutes with an outside temp. of about 61 degrees F??
  2. linuxpenguin
    linuxpenguin Active Member
    352
    182
    Sounds like the battery cooling fan--it has an intake on the right rear passenger side of the vehicle. I wouldn't worry about it. The fan is supposed to cool the battery pack in order to keep it in its most efficient temperature range regardless of outside ambient temperature. The battery will heat up after a lot of driving and will stay warm even over night since the battery has a pretty high thermal mass.
    Andrew
  3. duffasaurus
    177
    38
    Charlotte, NC
    Is this something new on the 2010 Prius since I've never heard this on an '07 or '09?
  4. linuxpenguin
    352
    182
    The Gen2 (2004-2009) wasn't as aggressive in cooling the batteries--as I understand it. I don't actually have a Gen3 so I can't comment further about that, but the cooling system is basically the same (the Gen3 just uses it more).
    Andrew
  5. Patrick Wong
    18,210
    6,513
    All Prius have traction battery cooling fans. While driving my vehicles, I've heard the fan come on, usually in warm weather.
    Tbkilb01 likes this.
  6. duffasaurus
    177
    38
    Charlotte, NC
    It makes sense that the cooling fan is operating more, because only recently have the daytime temps. moved into the 60's on a regular basis. When I first heard the noise, thought a window had been left open. :confused:
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    My grill is blocked almost 100%. OAT has been in the 60's & 72F over the last couple afternoons. The car sits outside all day & my commute is ~35miles, mostly highway 50-55mph posted (average speed is 30mph). Today the highest coolant temp I saw was 195F. I have yet to hear a fan spin up in either car.
  8. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    I had a candy wrapper flapping around in the fans basket before I cleaned it out and it was loud! The sound of the plastic flapping in there made the fan noticeable. I Certainly could hear the fan at the third level really turning to push air to battety. I kinda miss that wrapper! Let me know it was cooling! The fan runs really quiet. Next time I clean it I may reinsert a plastic wrapper. :D
  9. Mendel Leisk
    41,893
    I've monitored the speed of that fan with a ScanGaugeII, seen it go up to "4" (on a scale of 6?), but have yet to hear it. If yours is loud enough to easily hear, I would look into cleaning it. It's a relatively easy DIY to dig down to it, and you don't need to remove the fan itself to clean.
    BTW, if you're searching: it's not the "inverter cooling fan". Inverter is the component next to the engine. You could try "hybrid battery fan", something like that.
