inverter disc
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by 2 fas 4 u, Dec 3, 2014.
  1. Mike500
    Mike500 Senior Member
    2,593
    767
    First thing I'd check is for loose or broken engine mounts. That would cause a vibration.
    robertmaria and kithmo like this.
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    From Wikipedia:
    "Toyota introduced some refinements unique to the Prius v powertrain. These refinements include a new "Pitch and Bounce" motor control that the Prius v automatically employs on undulating roads and the refined control was designed to improve ride comfort and control. Because the Prius v is a larger vehicle with greater load capacity, suspension components were redesigned to improve handling and ride quality. "Pitch and Bounce" control works with the vehicle’s suspension to cancel longitudinal oscillation when the Prius v is driven over uneven surfaces"
    I wonder if this could be in play.
    kithmo likes this.
    52,568
    52,568
    pick up a salvage inverter disk and find a cheaper mechanic?
  5. GregP507
    GregP507 Senior Member
    3,002
    481
    I'm also confused by the term "inverter disc." Could it be the magnetic rotor inside one of the motor-generators? By going bad, I assume that something has come loose. Don't be surprised if a mechanic refuses to guarantee that a suspected problem is what it is; I wouldn't do that either. I don't see a short-cut out of this one. Looks like a case of "bite the bullet."
  6. Mike500
    2,593
    767
    A flaky "camshaft" or "crankshaft" position sensor or connection to those circuits might be at fault, even when there is no OBDII trouble code.
    I'd connect the car to TechStream or a ScanGauge II to read the performance data.
    TechStream would provde more information.
  7. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Trading it in is still the best fix. Although it might be worth more for parts than as a whole.
  8. mymigi
    mymigi Junior Member
    Dominican Republic
    I may be having the same issues on my 2010 III. The car will sometimes jerk from start and my remedy is to let off the gas and ease back on it. It will only do this with the gas engine. I have changed spark plugs and sent out my injectors to have them cleaned out. When driving it, it feels like it can be a motor mount but at the same time, it feels as if one of the injectors or coils are just lagging or shutting down.
  9. 2 fas 4 u
    2 fas 4 u Active Member
    320
    353
    florida
    From what the tech says there must be a cel whenever misfire occurs and I don't have any cel.
    going for second opinion today different dealer. Cost for check 69.00 oh well.
  10. bisco
    52,568
    you must make a fortune driving those kine of miles every year. it's worth keeping your car in tip top shape, you don't need any down time.(y)
  11. nsfbr
    nsfbr Member
    112
    30
    Northern Virginia
    2013 Prius v wagon
    Perhaps they are referring to the torque limiter/dampener that goes between the enginer and HSD? That would certainly point to them causing the problem when they replaced the engine.
  12. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    That is what I was thinking they were referring to. Some people mistake it as a clutch plate because it looks similar to a clutch plate. But as you state it is a torque limiter / dampener.
    I am not sure where they came up with the term inverter disc.
  13. GregP507
    3,002
    481
    There aren't many discs in this system. "Inverter-disc" would imply some sort of disc that converts DC to AC. So no one has come up with a reasonable explanation of what this might be.
  14. jdcollins5
    5,131
    1,346
    Wilmington, NC
    The OP stated that it is mounted between the Transaxle and the Engine. The only thing mounted between the transaxle and the engine is the Torque Limiter.
    This has nothing to do with converting DC to AC.
  15. bisco
    52,568
    or ac to dc.
  16. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I think 2Fas can return to the original installer and demand that the engine be installed correctly. If the installer damaged the torque dampener, he can replace that on his dime too.
  17. JC91006
    16,881
    8,621
    You have to remember he's gone 15,000 miles since
  18. SageBrush
    11,627
    2,533
    Southwest Colorado
    Yes, but that is ~ 5 weeks in 2Fas time.
  19. 2 fas 4 u
    320
    353
    florida
    Just left dealer #2 tech say the same as #1 did not give a name but said the disc engages the ice from the trans an should have been replaced before engine was put in oh well. Thanks for the suggestions.
  20. GregP507
    3,002
    481
    That would be called a "rectifier."
    ftl likes this.
