Inverter error P0A94 DC performance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by BrendonG, Nov 25, 2019.
  1. BrendonG
    BrendonG Junior Member
    Brisbane, Australia
    i-Tech
    Hi All, my 2009 Prius unfortunately threw this error last week. From what I have found in previous threads its the inverter unit that has gone, which is prone to failure anyway. Its driving fine still with reduced power. My questions are,
    1. Is it still OK to keep driving around? Im not sure exactly how its getting power to the wheels but seems to be happy if you keep acceleration under 1/3.
    2. Can I just grab a 2nd hand inverter from a wrecker and swap it out? Ive watched a few tutorials on this and have a mechanic as a friend. I'm aware we need to disconnect the HV pack before attempting any work.
    Thanks in advance for any advice
    Note: I am located in Australia and Toyota want to know nothing about it in regards to warranty.
  2. BrendonG
    Brisbane, Australia
    i-Tech
    Can anyone help with this at all? Its still driving around OK but I need to sort it out. Have found a part at local wreckers for $400 so would like to swap it out over the xmas break.
    Thanks
  3. BrendonG
    Brisbane, Australia
    i-Tech
    The part number I have located is G9200-47140 and is out of a 2011 prius
  4. Andrew Smillie
    Andrew Smillie Junior Member
    17
    Dallas, TX
    Did you ever get this figured out? I am having the same problem. Thanks
