Inverter Failure 2013 v no ready light many lightson
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Tim Jones, Jul 20, 2018.
  1. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Looking at fuses again.
    Thanks
    Raytheeagle likes this.
    52,891
    theres a lot of fuses in a prius. batteries, bonnet, drivers left leg...
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Agreed but a simple check;).
    If you’re doing the “throw parts at it” routine, staying in the shallow end avoids $$$:).
    But there are several locations to check and confirm(y).
  4. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Checked every fuse twice. All good.
    Thanks
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,134
    6,984
    Texas Hill Country
    There are two primary power contactors in the hv battery box that engage the hv battery to the cables. They are not being commanded on probably due to the stored codes which need to be cleared. Assuming, of course, there are no shorts or opens in the wiring. Probably needs Techstream obd2 to clear. A dealer or hybrid mechanic would have techstream equipment although you can buy a user pc bas3d system on ebay.
    If interested, here is a video about the battery assembly with the contactors and control logic around time 55. The orange service plug is at time 19 and the purpose later around 33. Also check out voltage sensing wires that can go open and cause codes around time 37.
    #25 rjparker, Jul 21, 2018
  6. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Where are the fuses on the HB battery.
    I see a resistor 3 relays and a metal box next to the batteries.
  7. bisco
    52,891
    idk, hopefully someone else does.
  8. rjparker
    11,134
    6,984
    Texas Hill Country
    I do not think there are fuses back there except the service plug.
    #28 rjparker, Jul 21, 2018
  9. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    There is a fuse in the orange plug. Might be worth a second look and verification it’s locked in place afterwards (y).
  10. rjparker
    11,134
    6,984
    Texas Hill Country
    Here is a drawing of the battery contactors which are controlled by the battery ecu and the network.. Battery in from bottom left.
    7DAB7AC7-64E4-44E9-8E71-D8D92A328D9E.jpeg .
    #30 rjparker, Jul 21, 2018
  11. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Thanks!!!!!!!
  12. rjparker
    11,134
    6,984
    Texas Hill Country
    I might suspect the original problem was the battery if that P308A code was there initially.
  13. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Thanks for the help. I'm pouring over any data sent to me.
    Tim
  14. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Thanks for the help
    I'm a fellow Texan....
  15. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Did the car fail while running or was t off then you started it back up?
    Any history of damage, or hit anything on the highway?
    Are you able to get under the car?
  16. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Yes
    Car was running great. Going about 35 mph barely stepped on the gas and car went into limp mode with abs, check engine and a few more lights.
    Thanks!!!
  17. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Did the replacement inverter come with a warranty?
    How do you know the used unit is good?
  18. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Both inverters came from junk yards. One with 22,000 miles the other 85,000 and the one in the car had 196,000. Not tested $200 each but can return.
  19. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Great video. Really explained how the back end works.
    Thanks!!!!
  20. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    If you’re confident the inverters are good, I’d start looking at the wiring between both for damage.
    Something is causing voltage to not transfer and setting the code.
