Inverter failure after repairs on coolant pump
Discussion in 'Prius v Technical Discussion' started by Melvin murphy, Aug 1, 2021.
  1. Melvin murphy
    Melvin murphy New Member
    Mississippi
    2013 Prius v wagon
    Recently purchased a 2013 Prius v , got a code for no flow on the inverter pump . After a little looking I found the wiring chafed going to the pump .I removed the three mounting bolts from the inverter just for a tad of clearance to access the wires . Made the proper repairs, cleared the codes ( Snapon Apollo ) code cleared . The car moved about 3 feet , shut down and now I have a poa08 dc/dc inverter status that will not clear . Never had this before pump repair . Verified wiring on the pump and pump is operating correctly . Any ideas
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Has the inverter TSB been done?
  3. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    So what happened?
  4. ChapmanF
    15,614
    I don't think P0A08 implicates the service campaign (whether it was done or not).
    In your post you don't actually say that you put the mounting bolts back and torqued them, before starting the car. Probably you just forgot to say that, but just to be certain: did you?
    The Repair Manual (more info) has about 23 pages of workup steps for getting to the bottom of a P0A08 code. Kind of hard to give a short Cliffs-notes summary. The code reports the power management control ECU getting funny status back from the DC/DC converter; the workup steps include both checking whether the status signal wiring is funny, or the wiring is ok and the actual status is funny for various possible reasons.
