Inverter High Pitch Noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by krausternet, Dec 18, 2013.
  1. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    I have a 2013 Prius. I was noticing a high pitch coming that I could hear when I had the driver side window down and the sound was reflecting against things I was driving by. It was strange because it didn't change pitch at different speeds, and it would be there most of the time regardless of whether I was speeding up or slowing down. And regardless of whether I was using the brakes or not. I've been told this is the sound of the inverter.
    I also started noticing that high pitch sound at about the same time that I had noticed a clanging sound coming from the front wheels when I hit a bump, or sometimes braked as if something was loose. This was in the first couple months of having the car. At the 5K check up I reported this and the dealer looked at it and said they found some suspension elements a little loose. The clanging sound was a little better but it was still there after they did that. And the inverter sound was definitely still there. At the 10K checkup I again reported the clanging sound. This time they said that I needed a new shim kit for the front brakes.
    They ordered it and I finally got around to getting it worked on yesterday. The clanging sound seems to be gone, AND I am noticing the high pitch inverter sound is much quieter. It is still there a little but I am happy that it is less loud.
    What do the brake shims have to do with the high pitch sound?
  2. mrbigh
    3,686
    699
    Long Island, NY
    If it is produced by the Inverter assembly, nothing to do.
    All Prius Inverters do make that type of High Pitch noise, it is the nature of the electronics.
  3. fuzzy1
    10,167
    Are you distinguishing the inverter whine from the pedestrian warning noise maker (VPNS), a.k.a. the 'spaceship noise'?
    As you age, your hearing cuts off more and more of the high pitched noises, bringing more tranquility. :) I can no longer hear the obnoxious horizontal rescan of CRT TVs. Dad couldn't find his pickup keys last week because he can no longer hear the whining key-in-ignition warning buzzer.
  4. WE0H
    WE0H Senior Member
    3,247
    527
    Prius makes all kinds of strange sounds. Park in a garage and power it down, then stand back for a few minutes and listen to the car go thru it's routines :) It's alive [​IMG]
    Mike
    mygel and Data Daedalus like this.
  5. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I hear it all the time plus a SUV tyres on tar road sound. The joys of tinittus!:(
  6. BreakingPrius
    BreakingPrius Junior Member
    35
    Mine sounds like a space ship sometimes.
    Data Daedalus and WE0H like this.
  7. bisco
    49,435
    i'm with you mate!:mad:
    Feri likes this.
  8. Data Daedalus
    Data Daedalus Senior Member
    1,022
    1,183
    Wembley, London
    I actually call mine "The Spaceship" for those reasons. It's amazing shutting down this vehicle and climbing out. As you might recover bits and bobs from the vehicle before you walk away, you can hear a whole series of noises one after the other as the onboard computer systems of your Prius "road going spaceship" continues to carry out its preprogrammed shut down sequence.
    Indeed I am reminded of THAT scene in Star Wars Episode V, after the Millenium Falcon has landed on the Landing Pad at Bespin Cloud City and makes a wide range of noises, venting gases, and other systems audibly shutting down even as the crew disembarked!
    It's at times like this that I realise what an amazing amount of work went into the Prius - literally ANY Prius.
    Yup......t'is indeed very like a spaceship :D
    iPad ? HD
    Feri likes this.
  9. Feri
    Feri Active Member
    761
    144
    May the force be with you!
  10. Data Daedalus
    1,022
    1,183
    Wembley, London
    Hahahaha :)
    Nexus 7 ?
