Inverter leaking?
Discussion in 'Generation 1 Prius Discussion' started by Williamtr3, Oct 15, 2019.
  1. Williamtr3
    Williamtr3 New Member
    Southeastern Virginia
    2003 Prius
    Howdy! I bought a 2003 (86k miles, new green bean battery) about a month ago. About a week ago I had a bunch of warning lights come on. I noticed the inverter coolant pump was low so I added some fluid and the problem seemed to go away.
    However I have been keeping an eye on The reservoir and noticed there is a leak in the system somewhere. It seems to be either leaking from the inverter itself or the connection from the reservoir to the pump (on the left side of the inverter casing)
    Has anyone had any similar issues, or can help diagnose the issue?
  2. Williamtr3
    2003 Prius
    In case anyone ends up with a similar issue...
    I believe the culprit was the two 10mm nuts that connect the coolant reservoir to the inverter. Driving through construction by my house likely wiggled them loose.. the coolant was then able to leak out
    mroberds, bisco and WHCSC like this.
  3. Q*bertZ
    Q*bertZ Member
    155
    38
    greenville south Carolina
    2002 Prius
    Did you get an insurance settlement on that car yet?
