Inverter pump/coolant flow question
Discussion in 'Gen 2 Prius Main Forum' started by CanTG, Mar 18, 2020.
  1. CanTG
    CanTG Junior Member
    2006 Prius, 130k ish miles. To be “preventative”, was checking all the fluids and checked the inverter coolant reservoir for turbulence. No turbulence. Pump is running, can feel vibration, and in hooking a line up to the bleeder valve and then into the inverter coolant reservoir, there is flow from the bleeder valve to the reservoir via the line with the pump running.
    Any idea why there’s no turbulence in the inverter coolant reservoir when the pump appears to be running? No codes or anything, however we are in Canada, so it’s not very warm yet ☺️
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Poor circulation means the pump is on its last legs. And like you said its not warm yet so has not thrown any codes yet. But it will.
    Fresh inverter coolant should look like its boiling in the reservoir. I would proactively replace the pump and coolant. Use the OEM pump. Few on eBay. You already know how to bleed it properly.
    While your at it remove the black plastic cover over the ICE radiator to get to the rad cap. Disregard the levels in the rad overflow tank thats meaningless for some reason in a G2 the rad could be empty and the overflow full. best to look inside the rad itself.
    You can leave the screws off that cover just fit it back on. The hood closed on it will hold it tight. No screws on my cover for about 10 years now.
    At least once a week I check the engine oil peek in the inverter reservoir and check the rad coolant level. keep the oil at the full line and the ice coolant at the top of the fill neck.
    This routine has served me well never any issues under the hood.
    My original pump was replaced under the years old pump TSB. Have 75,000 miles on it. Inverter coolant looks like its boiling. There will be a remarkable difference in circulation behavior between new coolant and what I suspect on your car the original coolant.
    Minima Domum and CanTG like this.
  3. CanTG
    CanTG Junior Member
    Thanks @edthefox5, I’ll start searching Canada to order an oem pump. Does it potentially look like this was replaced already (dealer records, appears to have been replaced 80,000 kms ago)
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    As a single data point, I've never noticed this boiling effect before. My OEM pump produced slight movement on the liquid surface area.
    I did replace a still working pump when a P0A93 appeared and cleared for no known reason, the aftermarket pump had the same movement.
    valde3 and Raytheeagle like this.
  5. edthefox5
    10,096
    4,837
    Clearwater, Florida
    SFO mine looks exactly like its boiling to a slow roll. It has no air in the system I bled it good. Much more agressive flow then the stock pump. I have tried posting a picture of it but cannot get the PC system to accept it. Even used a compression ap on my iPhone video still no go.
    To the OP yes looks like the car has had all its TSB updates including the steering shaft replacement and the inverter coolant pump. And they chopped the bottom inch off the gas pedal too which is that pedal safety check. back in the day during the Prius runaway car uproar disaster it was found the front floor mat would bunch up under the gas pedal and jam the gas pedal in the floored position.
    So they cut the bottom of the gas pedal off so a mat could go under it with no issue.
    But just because they replaced that pump years ago doesn't mean that one now hasn't failed. Very very common to lose that pump.
    Especially since the last pump was replaced by the dealer because they do not flush and bleed the system they use duckbill pliars and clamp off the input hose and slide a new pump in. So the car probably has the original invert coolant in it. That Inverter fluid is very abrasive after initial new car break in and that will kill a pump.
    It needs a new pump and complete flush of that coolant and refill with Toyota LLC coolant.
    I threw in a bottle of Redline Water Wetter in mine. Great product. I use it in the Ice coolant too. Inverter now runs very very cool about 100 degrees cooler than the engine temp in the dead of Florida summer.
    There is a very big spike in temp when you shut the car off the rad heat soaks the fluid. Both the rad and the inverter coolant share the rad in separate containers. They fixed that in G3/4 models by using a separate inverter rad.
    Good news you will get a bump in mileage with new coolant. Cooler the Inverter is the happier and more efficient it is.
    Good luck.
    #5 edthefox5, Mar 19, 2020
    CanTG likes this.
  6. CanTG
    CanTG Junior Member
    Ordered the new pump from Toyota today, should be here tomorrow (being in Canada, it was really a $20 difference getting it from Toyota). I’ll update once my husband gets a chance to get the new pump in and do a drain/refill/bleed of the coolant
    thanks for the insights, always appreciated!
  7. CanTG
    CanTG Junior Member
    My husband and I finally got around to doing this today, with all the info here and a few you tube videos, took under 2 hours to replace the inverter coolant pump and bleed the new coolant. There is now noticeable movement in the inverter coolant reservoir, not a super difficult job and for $100 well worth it to know this is now working.
    Thank you everybody on here for all the info!
  8. bisco
    52,760
    well done!(y)
    CanTG likes this.
  9. edthefox5
    10,096
    4,837
    Clearwater, Florida
    You should see a bump in mileage too.
  10. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    The OUTlet of the Inverter/Converter is the INlet of the reservoir, so any restriction between the pump and reservoir can cause this. I happen to have a photo of a partially blocked cooling plate from either poor maintenance or contamination.
    SFO and edthefox5 like this.
  11. richard203
    richard203 Member
    279
    61
    SF
    hm.. i should see if my inverter have a good flow too. lol
  12. edthefox5
    10,096
    4,837
    Clearwater, Florida
    The inverter coolant loop It has a huge cross section of aluminum cooling channels under the inverter. There very small Like 05 shows best to keep the fluid in tip top shape.
    I refer you to the excellent Weber Auto tutorials on the Prius on youtube. Just search Weber Auto on YT. They dissect a G2 and G3 prius and talk in length about there systems. Very informative.
    CanTG likes this.
  13. 05PreeUs
    1,097
    565
    MSP
    Yup! Professor John Kelly is AWESOME and I am glad his College allows him to not only make, but publish all those videos!
    Linky: WeberAuto - YouTube
    Meg&Bear, edthefox5 and valde3 like this.
  14. CanTG
    CanTG Junior Member
    Now I’m intrigued (I will admit I haven’t watched the videos!) - how does one get at this “cooling plate” to inspect it for any blockage?
    Meg&Bear and edthefox5 like this.
  15. 05PreeUs
    1,097
    565
    MSP
    You remove the inverter, drain it and pull the bottom plate (not the sheet metal cover) off.
    HOWEVER, I DO NOT recommend it! That plate can be difficult to reseal and there is a potential to damage the electronics in the inverter.
    edthefox5 and CanTG like this.
  16. CanTG
    CanTG Junior Member
    Note taken - I will not attempt it!
    Raytheeagle and edthefox5 like this.
  17. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Go see Webers videos its amazing how much cross section of cooling channels they get in that block. All pure aluminum which is very very hard on the coolant at least when its new. Raw aluminum in solution. Very abrasive. I surmise thats why they issued a TSB on the pump.
    After the initial break in fluid is replaced your good to go for the life of the car.
    Meg&Bear and CanTG like this.
  18. richard203
    richard203 Member
    279
    61
    SF
    so i went out today to check my inverter coolant reservior to see if theres any flow let me know if i need to change mines.
    Engine running
    Engine not Runing
  19. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    Looks good to me. No need to worry for a while.
  20. 05PreeUs
    1,097
    565
    MSP
    You have FLOW!
    It is not that the factory coolant causes the restriction, but CONTAMINATION of it that does. Despite what one may read on the interweb and while it *might not* do damage in some situations, mixing coolant types is NOT GOOD.
