Inverter Pump Failure - again! (200k miles later)
Discussion in 'Generation 1 Prius Discussion' started by DaveGoodrich, Sep 15, 2014.
  1. DaveGoodrich
    DaveGoodrich Member
    141
    68
    A couple days after I made the 350k update of my 1/3 million thread, I (actually, my wife) got the entire panel of dash lights and the CEL. My wife was driving in the 110 degree SoCal heat, idling in a drive through with the AC on when this happened. So it was hot. When I got there, I pulled the codes with a non prius-aware scanner and pulled the 3130 code. After it cooled down, I was able to reset the code. At that point, there was turbulence in the reservoir, so I chalked it up to possibly just being too hot. I drove it short distances over the next couple days, and all was fine.
    Then, on Saturday, I drove it about 30 miles in the mid-day heat and the warning lights and 3130 code reappeared. After it cooled down (after my round of golf, actually) I was able to clear the codes/warning lights, but this time there was no visible flow/turbulence in the reservoir, so the pump is apparently shot. It was pretty cool by then, and it was mostly downhill to my house, so I was able to drive it home with no issues.
    I replaced the inverter coolant pump once before, at about 157k miles. I can't believe I have driven this car almost 200k miles since I replaced the pump in 2009. I bet not too many owners have worn two of these things out.
    Yesterday, I got it taken apart and ready for the replacement pump. I've seen the pump for around $115 from a couple of online parts houses. Anyone have a recommendation for one of these places that they have been satisfied with?
    telmo744 likes this.
  2. JC91006
    16,939
    8,647
  3. DaveGoodrich
    DaveGoodrich Member
    141
    68
  4. JC91006
    16,939
    8,647
    Most of the online Toyota dealerships are great. I personally order from this place for all my Toyota parts. Buy $150 and it's free shipping. No tax outside of AZ
  5. DaveGoodrich
    DaveGoodrich Member
    141
    68
    Awesome. I wonder if the coolant can be shipped. That would get me over the $150.
  6. JC91006
    16,939
    8,647
    This place is actually cheaper for parts and they ship the coolant too. They charge for shipping but sell the parts cheaper. Almost a break even and no minimum to meet.
    EB TOYOTA PARTS | toyotaparts.bochtoyotasouth.com
    SLLC part is 00272-SLLC2
  7. DaveGoodrich
    DaveGoodrich Member
    141
    68
    OK, I ordered the part and will buy the coolant from the local dealer.
    When I did this before, I remember having some sort of guide on how to do the bleeding after I change the pump. I can't seem to find whatever it is I had. Anyone have any good advice on making the bleeding easier? I seem to remember it taking a long time, and never really seeming like I really got all the air out (I must have done ok, my inverter is still functioning 200k miles later).
    I found this thread. I will go with Patrick Wong's bleeding procedure in that thread unless I get any other good advice.
    Thanks,
  8. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    It was not hard and did not take to long when I just did this. I did not need the tubing from the bleeders back to the resevoir as I just had a rag underneath the bleeders to catch the small amounts of coolant. I had the car at an incline and kept squeezing the coolant hoses and opening the bleeders with the ignition in the READY position topping off the coolant as I went along. I did this to long cause my 12V died but in that amount of time I was done.
    TomK
    robert mencl likes this.
  9. DaveGoodrich
    DaveGoodrich Member
    141
    68
    1st replacement pump at 150k miles, 2nd at 350k miles. Next pump at 500k?
    3rd pump installed this weekend. Somehow much easier to bleed this time. Old coolant looked perfectly clean after 200k miles.
  10. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    WOW! I thought this fluid was only to be used for about 50K miles, the SLL fluid that is and you went 200K miles.
    Glad the bleeding was no trouble.
    TomK
  11. DaveGoodrich
    DaveGoodrich Member
    141
    68
    Yep, I am not a stickler for fluid change intervals! I drained it into a clean, white pan, and was amazed that the old fluid looked exactly like the new fluid. No (observable) evidence of any debris or corrosion after 200k miles.
