Inverter pump not pumping
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dummy, Oct 8, 2022.
  1. Dummy
    Dummy Member
    121
    23
    Colorado
    My dash lit up like a Christmas tree and the code says it’s the inverter pump. I opened the reservoir and the coolant isn’t moving. I would like to rule out any fuse or relay issues before I swap the pump. Can you tell me all of the things to check?
    The lights that come at the same time are the red triangle, check engine, yellow circle with !, and VSC
    #1 Dummy, Oct 8, 2022
  2. JC91006
    16,939
    8,647
    From my experience with the pump failure, it would only light up the red triangle. If you have a bunch of lights that turned on, you may have additional problems. But I would first start with the pump if you are getting the code P0a93 and notice no movement in the coolant.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Those pumps seems to last 80-90k miles
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    Well, you could unplug the connector at the pump, power up the car, and test for power and ground. The white wire with black stripe in the connector should be ground, and the other wire should 12V.
  5. Dummy
    Dummy Member
    121
    23
    Colorado
    yep that’s the code and I have no movement. Why wouldn’t I check fuses/relays first?
  6. Dummy
    Dummy Member
    121
    23
    Colorado
    I’ll try that. If there’s no power what should I check?
  7. ChapmanF
    19,059
    In the unlikely event you find no power, you can check with us and we'll go from there. In the likely event that power is ok, you already know what comes next.
  8. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Inverter coolant pumps don't last forever; when was the last time it was changed, and did you use an OEM pump?
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    The Inverter Cooling Water Pump receives power through the AM2 fuse. If the AM2 fuse were blown, the entire car would be dead.
    ColoradoCrow and jerrymildred like this.
  10. ChapmanF
    19,059
    Well, parts of the car would power up and work—those on other fuses—but it definitely wouldn't be taking you anywhere.
    jerrymildred likes this.
  11. Dummy
    Dummy Member
    121
    23
    Colorado
    The pump has started pumping again. I turned the car on and removed the coolant cap. I then squeezed the hose to see if I could feel movement. When I let go I could see movement in the reservoir. Is this a freak occurrence?
  12. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    @Dummy - just be patient, and wait for the pump to finally fail, and if lucky it will blow the AM2 fuse first.
  13. Dummy
    Dummy Member
    121
    23
    Colorado
    I don’t know when it was changed last. I bought it at 180k and it has about 210k now.
  14. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Well, a lot of us had a recall on it inverter pump replacement at the ~50-80k mark. So somewhere around 170k I had to replace again on my own nickel. If this is only your second pump, you are probably overdue.
    These are amazing 12v pumps, some find other non-car uses. But they do not last forever.
  15. mr_guy_mann
    4,120
    2,018
    NJ-USA
    It's a not unheard of failure mode (esp for aftermarket pumps). I would replace the pump ASAP.
    I did mine last year (just because) and used a Toyota part. More expensive than AM units but to me the difference in price isn't worth the possible problems of it failing sooner.
    YMMV
