Inverter pump torque spec
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pdaddy, Mar 14, 2021.
  1. Pdaddy
    Pdaddy Member
    160
    49
    How tight should the inverter pump be torqued to the mounting plate? It has some dampening washers on it-- should it be somewhat loose?
    SM-G960U ?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,089
    Columbia, SC
    Those rubber 'washers' should each have a metal standoff tube in the center. That 'stand-off' metal tube prevents the mounting bolt from actually being torqued onto the pump housing. Tighten the bolts until they're against the stand-off tube. The pump will feel loose, but it is properly mounted to minimize vibration transmission.
  3. Pdaddy
    Pdaddy Member
    160
    49
    Ok thanks! I changed the pump and left the originol base on and only had to take off the front engine cowling. No need to remove headlight or losen inverter. Helps to have a long needle nose pliers for the clips and a knuckle socket for the bolt under the inverter brace.
    SM-G960U ?
