Inverter pump wont run
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tallman, Aug 15, 2021.
  1. tallman
    tallman Junior Member
    60
    wv
    Getting code p0a94 getting power to the two outside contacts on the pump on the car,, it runs on the ground with power to the outside contacts but will not run connected to the car connection, good power going to pump on the car, replaced pump checked fuses and connections, car starts and shuts down after resetting
  2. Mendel Leisk
    42,384
    Clean up on aisle 6. :D
  3. Deener77
    Deener77 Junior Member
    Dublin California
    Here's a link on YouTube with someone who had the same code and disgnosed and fixed it wish I could be more help good luck
    tallman likes this.
  4. Deener77
    Dublin California
    Here is the full manual for a gen 3 prius
    tallman likes this.
  5. tallman
    60
    wv
    What will run this ? it says no app found to run it
  6. tallman
    60
    wv
    For gen 2 but did give me a few leads thanks
