Inverter radiator leaking/replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Flaninacupboard, May 27, 2011.
  1. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Consider yourself lucky it's just the inverter radiator and not the inverter too. The inverter is very expensive to replace, and it might be on back order status as well.
    After you get it fixed, consider mounting fine mesh metal or plastic behind the upper and lower grills to protect from exactly that kind of damage from rocks and stones small enough to get in there, but large enough to do damage.
    SCH-I535
    #21 xliderider, Aug 25, 2014
  2. Shampa
    Shampa New Member
    Madera ca.
    Newbie ! I just found my inverter cooler has a leak in the same area.before i found where leak was coming from i removed plastic under carriage and a rock the size of marble fell out ! Stealership said 389.46 new factory part special order.found a salvage one online 167.00 . About year ago replaced front spoiler a bird hit it and cracked it !
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    It looks like a simple enough DIY repair.
    I've learned to appreciate outrageous dealer prices. All the more satisfaction for me :)
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Insurance, not Warranty, People.
  5. Bingee
    Bingee Member
    210
    62
    Michigan
    My windshield gets stone chip / broken , my insurance covers the damage .. Why not for this also
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    Read your contract. It exists to tell you what is covered.
