Inverter radiator replacement--$1100?!?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by worktheweb, May 16, 2012.
  1. worktheweb
    worktheweb New Member
    Virginia
    I was driving to work this AM in my 2010 Prius and got the yellow triangle and associated hybrid system error message. Dropped it off at the dealer and got quoted $1100 to replace the inverter radiator. They called it the "hybrid radiator" but it's the same thing. I guess a rock went in the grille and punctured it.
    This is Koon's Toyota in Arlington, VA in case you're wondering. $1100 seems like a total hatchet job to me but the service tech said they have to remove the bumper and associated hardware to get to the radiator.
    Any ideas? I told the guy I would get back to him.
  2. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    I'm guessing they're not covering it under warranty because they claim a rock punctured it?
    Maybe give your insurance co a call... collision with foreign object?
  3. worktheweb
    Virginia
    Yep, my first question was "This isn't covered by my warranty?!?" Nope. Collision with external object.
    My deductible is $1000 so that's no good. I would never use insurance unless it was a major catastrophe anyway.
  4. Vege-Taco
    Vege-Taco Junior Member
    78
    Arizona
    Junkyard? If you can find a wrecked Prius that wasn't in a front-end collision...
  5. Vege-Taco
    78
    Arizona
    $121 on ebay.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ +1 plus say about $40 in coolant and a few hours of work.... piece of cake.
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The 2010 Service Manual shows the hybrid radiator assembly sitting right on top of the ICE radiator. It does show removing the front bumper and then the top radiator support. If you are DIY inclined at all it should be a pretty simple replacement. Or a good mechanic should be able to do it easily. Just be sure to use the Toyota SLLC coolant when replacing.
    Find the diagram attached.
  8. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
  9. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    You are probably already facing a $500 charge for diagnostics (they took it apart, right?). I'd say it's an expensive lesson. Ask another dealer what they charge just to confirm whether this dealer is on the level.
    At any rate, welcome to the modern world of dealer servicing.
  10. worktheweb
    Virginia
    Thankfully they diagnosed it for "free" probably because I also had them do the $100 oil change/27 pt. check. Whatever. I found the radiator at 1-800-RADIATOR for $158 so I'll give it a shot. If not I found a shop that said there's no way that job should cost more that $500 radiator included.
  11. jdcollins5
    5,131
    1,346
    Wilmington, NC
    For a reference cost the Toyota 2010 Prius Parts Manual shows the following:
    Cooler, Inverter - Part No. G9010-47030 $367.31
  12. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Should be covered under the cheaper comprehensive deductible. Some road debris punctured the gas tank in a previous car and it was only $240 for me, covered under comprehensive (Farmers).
  13. hlunde
    hlunde Member
    419
    75
    If not branded, then it's most likely Chinese.
    I recommend that you use original Toyota part. There's still a major savings if you do the work yourself.
  14. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    It's also possible to find the part from a wrecked Prius.
  15. El Dobro
    El Dobro A Member
    7,106
    3,282
  16. David Beale
    5,963
    1,990
    Edmonton Alberta
    Too late for you, but for others....
    I went to the hardware store and found eavestrough mesh (aluminum). Removed the fasteners under the front of the car and folded back the undertray, then fed the mesh up behind the grill. Zip-tied the mesh to the grill using black zip-ties. The result is no insects embedded in the radiators and no damage from rocks etc.
  17. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Can't you take it to a good radiator shop and just have it repaired properly for $100 ????
    REV
  18. El Dobro
    El Dobro A Member
    7,106
    3,282
    I'd give it a shot, that's what I used to do.
  19. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    I've looked at the manual, and the tricky part is refilling/purging the radiator. That takes a dealership computer to turn the pump on. Not sure how a radiator shop or a home mechanic can do that. It would be wise to ask a private shop about this.
  20. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Dealerships are a crapshoot IMO. After my trying to buy my Prius from them (Koons Tysons Toyota) back in February, the games they played on my trade (I was willing to take $7k, they offered $5k with lies about about calling the local Subaru dealership about the value of my 2003 Baja. Only to raise it to $7k the next day as I sat at Carmax Toyota with a $9k offer and a sweet deal on a 2012).
    Call me old fashioned, but the way you are dealt with in buying shows you where they stand in the service side of things. So Koons would be the LAST place I will ever go to for service.
