inverter rebuild / troubleshooting - Voltage insulation fault P0AA6 526/614
Discussion in 'Gen 2 Prius Technical Discussion' started by tri4all, Dec 21, 2019.
  1. yes
    0 vote(s)
    0.0%
  2. no
    5 vote(s)
    100.0%
  1. ChapmanF
    18,240
    Right before the paragraph you chose to quote was the one you chose to leave out:
  2. tri4all
    tri4all Member
    99
    Pacific Northwest
    I am still not sure what your point is or if you are still confused about why I had to use the generic 526 code? I explained it several times. read posts #4, 11, and 20.
    Also, step 16 of the manual needs to be rewritten as for testing the frame wire. read Wardtp's thread for more details. let's keep this thread for only inverter rebuild troubleshooting.
  3. ChapmanF
    18,240
    You mean you're not sure why I included a paragraph that specifically said "I understand you had a reason" and repeated your reason? That's why you think I didn't understand your reason?
    I've already commented on Wardtp's thread to get more details on the "step 16 needs to be rewritten" theory.
  4. Sonic_TH
    Sonic_TH Active Member
    573
    96
    Puerto Rico
    2016 Prius c
    So what was wrong with the frame wire?
  5. Debo160
    Debo160 Junior Member
    MORTH CAROLINA
    Does anyone have a picture and location of this frame wire?
  6. ChapmanF
    18,240
