Inverter usage
Discussion in 'Gen 3 Prius Main Forum' started by abdullah arslan, Mar 31, 2025.
  1. abdullah arslan
    189
    79
    Got a power outage for 2 days, and I have an inverter. Is it better to hook it up on 2010 Prius or 2017 highlander?
    To supply refrigerator and freezer mostly
    52,831
    prius will use less gas
  3. abdullah arslan
    189
    79
    I guess safe to use, too. Hooking up to 12V or plug in fuse box ?
  4. Tombukt2
    Tombukt2 Senior Member
    13,848
    2,515
    Durham NC
    Wow you're going to have enough voltage from a 12 volt battery and a Prius which is quite small to run 120 volt refrigerator and whatever else you said in this thing that doesn't seem good to be honest about it but maybe I would think you'd want to be pulling off the big battery some kind of way That's what you power the house with I thought.
  5. PriusCamper
    PriusCamper Senior Member
    13,451
    5,430
    Pacific Northwest, USA
    Highlander has a bigger high voltage battery to keep the 12v battery charged so engine will run less often to charge the hybrid battery.
  6. ChapmanF
    19,009
    and run longer when it does
  7. bisco
    52,831
    There are lots of threads about how to run an inverter off of the 12 volt.
    I suggest reading through one or more.
    I think you need pretty heavy cables coming off of the battery, iirc
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,079
    6,940
    Texas Hill Country
    You need to connect directly to the 12v battery and keep the car in Ready so that the inverter converter supplies the power.
    A lot depends on the power your refrigerator and your freezer pulls. Assuming you are talking separate devices, they could draw 750 watts each for a total of 1500 watts. Even if they are smaller or more efficient the startup amp draw requires a decent sized setup like a 1500 watt inverter. That size inverter will draw 100 amps on 12v power depending on the actual load and really needs 4 awg wires or bigger.
    #8 rjparker, Mar 31, 2025
    Tombukt2 and abdullah arslan like this.
  9. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    I will add that in order to avoid unproductive expenses in the preparedness mode, it is worth turning off all possible equipment in the car as much as possible.
    Headlights, lighting outside and inside, the dashboard should be darkened as much as possible, turn off the radio, air conditioning, various connected gadgets, cameras, scanners, etc.
    And the shorter and thicker the connection cables, the less losses.
    abdullah arslan likes this.
  10. abdullah arslan
    189
    79
    Thanks everyone, ran the highlander about 2 hours, just only hooked up a refrigerator and small items to charge up. The battery terminals were pretty hot when unplugging the inverter
  11. rjparker
    11,079
    6,940
    Texas Hill Country
    That means the connection was poor. Generally you need lugs that are bolted on to the battery terminals.
    #11 rjparker, Apr 1, 2025
