Inverter water pump failure
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by twindad2002, Dec 4, 2012.
  1. Patrick Wong
    18,214
    6,531
    The pump you ordered is incorrect.
    Skibob and Raytheeagle like this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    x2
    or at minimum, the pump you received is incorrect....
    Simple and to the point...
    what water pump failed? where is it located on the car? what DTC code did you receive?
  3. gbond
    gbond New Member
    Illinois
    AM2 fuse is blown
  4. gbond
    gbond New Member
    Illinois
    it is up by the left light
  5. TMR-JWAP
    6,404
    6,099
    Columbia, SC
    How did we go from your "new pump having 5 prongs" to the AM2 fuse being blown. The AM2 fuse is the power path for the inverter cooling water pump. It's very well known that the AM2 fuse will blow in about 50% of the cases where the ICWP fails. When it blows, it kills the dash and the car. That information is posted in the forum in hundreds of different threads. We could have helped you instantly if you had asked about that.
    We're curious what your determination was about your pump. Fill us in?
