Inverter water pump going bad?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Shaun H, Jun 29, 2026.
  1. Shaun H
    Shaun H New Member
    Gilbert, AZ
    2015 Prius v wagon
    I noticed my MG1 and MG2 get to about 200 degrees Fahrenheit after delivering food for two hours in 100-110 degree Arizona weather. It seems like the acceleration is not as good as when it’s cooler. Wondering if maybe the water pump is going out and not able to keep up?
    I’m using hybrid app to monitor temps.
  2. Higgins909
    Higgins909 Member
    289
    71
    I think it's normal. IIRC, I hit almost 300 when I tow my boat. Something like 240 when I would Uber. BTA would hit 200 all the time. I confused it with BTA or maybe I'm confusing them now. One is the HVB and the other is a part of MG1 or something like that. Scangauge 2.
  3. PriusCamper
    PriusCamper Senior Member
    13,452
    5,430
    Pacific Northwest, USA
    You'll get warning lights and error codes if anything goes wrong... What you're probably experiencing is the computers are balancing the gas engine with the electric motor differently than they would if the weather was less extreme. Another symptom you might notice is the computers send less power to the AC system and it won't work as well at full blast.
  4. PTS
    PTS Member
    99
    49
    Austin, Texas
    2013 Prius v wagon
    MG2 alarm limit is 374f
    MG1 alarm limit is 232f
    Inverter coolant temp is more likely to code with a 149f limit
    Higgins909, PriusCamper and Brian1954 like this.
