Invisible qi mod (wireless phone charging)
Discussion in 'Prius v Accessories and Modifications' started by Piet25, Jan 1, 2021.
  1. Piet25
    Piet25 New Member
    Netherlands
    I moddet my prius v and add qi charging to the center console.
    By sharing I hope to insipre other Prius drivers.
    On the front of the center console there is a flat spot.
    Using a opening tool I removed the plastic part.
    Ones I got it loose I took it inside to work on it.
    I tested the best spot for the QI charger using a 3S lipo. Once I found Sweet spot I used a knife to make shure the QI coils were as close to the plastic surface as posible. I installed the PCB using a hot glue gun.
    Using a multimeter to check the 12v line from the 12v socket, it measured 14v witch was no problem for the QI charger, it can handle 12 to 24volt.
    I needed to cut the wire of the 12v socket to add the QI charger. I used heatshrink tubes that contain tin to make a nice solder joint.
    As you can see in the video the phone in charing in any directory. This is because i used a 3 coil charger.
    #1 Piet25, Jan 1, 2021
    gromittoo, AandMev and lrisius like this.
  2. lrisius
    lrisius Member
    120
    56
    Illinois
    2015 Prius v wagon
    That is pretty slick. What did you use/where did you get the charging unit?
  3. Piet25
    Piet25 New Member
    Netherlands
    Thnx, you can purchase these "qi charger diy" units from ebay or even aliexpress. Just searched for QI DIY
    lrisius likes this.
  4. Kaiso
    Kaiso New Member
    Los Angeles
    2017 Prius v wagon
    Very cool. It is a mod I'm interesting in doing myself. My V is 2017 so slightly different.
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    Any issues with the phone sliding off?
    gromittoo likes this.
