Ioniq 5 News Thread
Discussion in 'Hyundai/Kia/Genesis Hybrids and EVs' started by Tideland Prius, Feb 23, 2021.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Well, the ones I like aren't available in this exact size, so I chose the next closest one (which is very close):
    255 45R20 - $283
    245 65R17 - $181
    Tideland Prius likes this.
  2. Trollbait
    12,831
    They do if the point is give ground clearance for a battery pack.
    Tires on US Camry hybrids range from P205/65R16 to P235/40R190. Maintaining the same width isn't a must, and the narrower tire with smaller wheel would also improve the efficiency for the BEV too. The only technical limitation I can think of is the tires for the smaller rims not having a high enough load rating for a long range BEV.
    Now with the high torque of BEVs, and tires just starting to come out that can handle that without premature wear, tires will likely be a pricier item for a BEV in the near future either way.
  3. Tideland Prius
    16,681
    No but I assume the XLEs are heavier than the LEs so they probably benefit from the wider tyres. (And it's always been the case but I believe this is the largest they've had the gap between the width of the base model and the top model).
    That said, Ford went with 225 width tyres for the Mach-E while VW went with 235 fronts, 255 rears.
