iOs 4.1 sound quality issue using USB adapter
Discussion in 'Gen 3 Prius Audio and Electronics' started by sacharod, Sep 9, 2010.
  1. Thai
    Thai Prius Neophyte
    1,197
    89
    Have you tried hooking it up via USB? Static with USB?
  2. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    Yep! Same thing here! Audio problems started JUST LAST NIGHT after an iPod Automatic Update yesterday afternoon!
    At first I thought it was my iPod Touch (3rd generation), but after using the iPod in other places and with my earphones I quickly realized that the Prius was the ONLY place I was having a sound quality issue. Today I wiped my iPod back to factory settings in the hopes that a previous software version gets re-installed. I'm interested to read what others have done, and more importantly, if there is a fix -- other than wiping the unit altogether of course.
    P.S. I have gone into Settings/Preferences and unchecked the box that allows for "Automatic Software Updates".
  3. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    Yeah, same here, my BT was off when this was happening ...
  4. Thai
    Thai Prius Neophyte
    1,197
    89
    See my previous post (#18 on page 2)...the Apple tech told me that there is no way to re-install a older software version. :( Restoring the whole Itouch does NOT work.
  5. priuscritter
    priuscritter I am the Stig.
    1,525
    199
    Indiana
    there most likely is an unauthorized way to go back on the software, but not from apple or itunes. it probably requires a jailbreak and then getting the older software from a third party site.
    luckily the aux jack was not affected with the update. my tunes sound good.
  6. Thai
    Thai Prius Neophyte
    1,197
    89
    Since BT Audio streaming is an option, i rather use BT Audio streaming because i can skip songs with steering wheel controls...without having to fiddle with my Itouch. Still, i prefer USB, but with the static, BT Audio sounds better. :mad:
  7. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    USB is my preference -- I like the added information on the NAV display, but hey, in a pinch the BT is fine.
  8. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    So, did Apple fix this yet?
  9. tony6905
    tony6905 New Member
    FL
    Everything was working fine until I went to a os 3.1.4 to 4.1 now i'm getting the same problem and I worked a whole week with apple tec and said wait for the 4.5 up grade in 6 months.
  10. tony6905
    tony6905 New Member
    FL
    Not knowing other people were having this problem.
    Last week I up graded my IPOD T from OS 3.1.3 to 4.1. Then I starting the skips when using the USB connector. I reported to Apple they send me a new IPOD with the 3.1.3 OS and that worked fine. Apple knows about the problem and said they will have a fix in six months (good Luck).
  11. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    First, I find it hard to believe that Apple sent you a new one, and secondly I find it even HARDER to believe that Apple will not have a fix for 6 months? Where do you get this stuff from?
  12. tony6905
    tony6905 New Member
    FL
    By setting the IPOD to factory setting It clears everything of the IPOD and keeps the latest ios update in this case IOS 4.1
  13. tony6905
    tony6905 New Member
    FL
    Apple did not send me a new one I had to go to a Apple store and exchanged the one I had (which I had for only 3 weeks) to a new one. Then when I brought it home the tec said go ahead and up grade the new one from 3.1.3 to 4.1 and i got the same problem again. That one I overnight shipped bak to Apple and they did a diagnostic test and said nothing was wrong with it. and sent it back.
    The technician said most likely the next IOS up date will be in 6 months he was not talking about a fix. Supposedly they were not aware of this problem. So i sent them a link from this forum and the Prius forum discussing this problem. WHAT MORE CAN WE DO???
  14. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    So, did Apple fix this yet?:confused:
  15. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    ughh! Are we getting angry at Apple yet?
  16. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
  17. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
