ios 5, Audible app and iPhone integration
Discussion in 'Prius c Main Forum' started by hybridtwins, Feb 26, 2012.
  1. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    All,
    My wife listens to audio books from Audible.com on her iPhone. As of ios 5, there is now a dedicated Audible app to play back the content, and if I understand correctly, that content no longer resides in the iPod music library. So is there any way to access the content via the MFD when the iPhone is hooked up via USB? Could the Audible app perhaps be accessed via Entune? :confused:
  2. Jayin
    Jayin Future "C" Owner
    Fresno
    Don't know if this is the right forum for your question sir. Have you tried creating a playlist for each audio book. I'm not familiar with this specific system but I know most ipod head ends will let you access the playlist section.
  3. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    Okay... after doing more research, I understand that Entune is primarily a cloud/streaming environment, so is not pertinent to my question. I was able to download an audiobook directly into iTunes and then sync the content to my iPhone, thus bypassing the Audible app. So I guess the issue is really between Audible.com and iTunes.
  4. wongnog
    wongnog Member
    125
    26
    Toronto
    Technology
    If you get the c3 or c4 they have Bluetooth audio streaming (lower models have Bluetooth hands free calling only), which will play any audio from a Bluetooth device like an iPhone.
  5. Tek55
    Tek55 Junior Member
    96
    Houston
    If audible allows for airplay support, even with a lower model C, you can output via bluetooth and use audible content from within the audible app.
    That is, provided audible allows for bluetooth audio output.
    If a little box with an arrow in it shows up when your phone is paired with the vehicle and you try to use the phone, then you can just select your vehicle and output to it.
  6. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I cannot access Audible from the Entune system. I simply stream it from my phone via Bluetooth and it works just fine.
  7. PlutoISaPlanet
    PlutoISaPlanet New Member
    San Diego
    that's not true. My II has Bluetooth audio streaming.
  8. jdk0827
    jdk0827 Junior Member
    16
    Laguna niguel
    2019 Prius
  9. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    You could put the Audible books in the phones iPod app vs. the Audible app.
    I love listening to my Audible books in the car via the Bluetooth audio connection.
    If you want to use the Audible app, couldn't you plug the iPhone into the cars Aux connection, like an MP3 player and listen to the Audible app that way?
