iOS13 CarPlay
Discussion in 'Prime Audio, Electronics, and Infotainment' started by tillyvick14, Sep 21, 2019.
  1. tillyvick14
    tillyvick14 Junior Member
    25
    Albuquerque, NM
    2020 Prius Prime
    The iOS13 release this week provided a good upgrade to CarPlay like the new dashboard view, cover art, etc.
    One issue I am having so far is that the maps navigation command volume does not seem to be able to be adjusted independent of the music volume the way it can on most cars. Has anyone else encountered this and found a solution?
  2. Tideland Prius
    16,673
    There's a setting in Google Maps that has "Softer", "Normal" and "Louder" for voice guidance. Could that help?
  3. tillyvick14
    25
    Albuquerque, NM
    2020 Prius Prime
    Unfortunately that doesn’t seem to help. It makes the volume louder but if your music via Apple Music is turned up it will still drown out the navigation voice. On other cars you have to wait until the navigation voice is speaking and increase the volume as the navigation voice and music have separate volume level controls. On our Prius Prime there seems to only be one volume level which is not useful.
  4. Leadfoot J. McCoalroller
    8,275
    7,777
    Pennsylvania
    2018 Prius c
    In ios12, the voice guidance volume is part of the navigation app settings (Apple Maps/google/waze etc) not phone settings. I haven’t upgraded so I don’t know if it’s the same in 13.
  5. Michael-dvc
    Michael-dvc Junior Member
    San Diego
    Toyota isn’t supporting to lower the volume of the music when Apple navigation is on. There’s another thread about this.
  6. tillyvick14
    25
    Albuquerque, NM
    2020 Prius Prime
    Can you link to the other thread? Sorry I haven’t been able to find it by searching the forum.
  7. Travis64
    Travis64 Member
    Ny
    Can someone make video of how apple carplay looks on the prime?
  8. TommyTech
    TommyTech New Member
    San Diego
    2020 Prius Prime
    I was expecting this behavior as well. I wish it worked that way. :-/
    You can change the navigation voice volume, though, by doing the following:
    Choose "Menu" => "Settings" => "Voice", then set the Voice Volume, from 1-7 (or none) I think the default is 4, which is too loud for my taste. I set it to 2.
    On your iPhone, in the settings app, under "Maps" => "Driving & Navigation" => "Navigation Voice Volume", if you set it to Normal or Loud, then the audio from your iPhone should drop when navigation comes on.
    Note: if the audio is coming from the car, e.g. AM/FM/Sat Radio, then the audio volume does not drop when CarPlay navigation kicks in.
    pghyndman likes this.
