iPad in prius
Discussion in 'Gen 3 Prius Audio and Electronics' started by eco-icon, Sep 2, 2012.
  1. eco-icon
    eco-icon Junior Member
    137
    anyone knows where to have it installed?
    52,849
    not many options.
  3. Cvk14
    Cvk14 Junior Member
    37
    New York, NY
    i once saw a picture of someone using a bungee cord with two hooks to use the middle 2 vents to mount an iPad over the stereo.
    jtmahoney likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,461
    5,431
    Pacific Northwest, USA
    Most any car stereo installation place will put something together for you... Also just pick out an Ipod case that matches your interior and then velcro or glue or bolt that case to your dash in the most convenient place.
    More to the point simply type into Google "Ipad Prius" you'll get a half-dozen you tube videos of people who have done this as well as lots of other options. You also can do an image search to see even more ideas.
  5. Jeff Hubert
    Jeff Hubert New Member
    I'm almost finished with an install of an iPad mini, sub, amp, and new front and back speakers. I'll post som pics on Tuesday.
  6. DaWeav
    DaWeav Junior Member
    91
    Lemoore, CA
    I have a seat mount from
    RAM Mounting Systems, Inc.
    which I had in my 2005 Prius since it installs by just using the bottom bolt holding the seat. I haven't tried putting it in my new 2013 yet since the 2013 has the center console compared to the 2005, but Ram Mounts has a lot of different options for all types of tablets.
    GT-P7310 ? HD
  7. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
  8. Jeff Hubert
    Here are some pictures of my iPad Mini in my car using a cd mount and the Hertz component speakers I put in the rear. The rear speaker install was very easy. The 6.5" woofer replace the factory speaker using he existing bracket. I had to grind out the bracket a little to make it fit. The tweeters look almost factory. There was a space behind the door in the upper right corner that was a perfect fit for the crossover.
    I use both a iphone 5 in the car as well as the iPad mini. I wanted the music playing from the iPad mini to fade out when a call came in and fade in when the call terminated. The factory head unit can only pair with one device at a time. So Inneded another solution. I used a Blackberry Stereo Gateway bluetooth adapter plugged into the aux. port and paired the iPad with that and paired the iphone 5 with the factory units bluetooth. This works perfectly!
    I left the original speakers in the dash and replaced the front doors with 6x9 Hertz HCX-690.
  9. zhutton
    zhutton Junior Member
    85
    Staffordshire, UK
    Sweet, how's that bounce around on the road?
  10. Jeff Hubert
    It doesn't bounce at all unless I hit a big bump in the road. The part that inserts into the cd player is made of dense rubber so it will give nicely if bumped.
  11. zhutton
    85
    Staffordshire, UK
    Awesome, nothing annoys me more than my phone bouncing and buzzing round when I'm driving and I can't see the screen
  12. going red baby!
    610
    96
    Los Angeles
    Interesting. Who makes that? Can it be turned so the tablet is below rather than above?
    I just came upon this cd mount today. This one works for me since I just want to cover my existing unit but it doesn't look as sturdy as that one, although this guy has a video up of him driving over a bumpy road for a while and everything remained intact.
  13. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
  14. Jeff Hubert
    The part of the unit that holds the iPad is on a slider. So it can be lowered or centered or rotated to adjust how you want. I prefer to have it raised so I can easily access both screens.
  15. wsbsteven
    wsbsteven Prius owner gone Leafer
    24
    Saint Louis
    So who makes that cd mount?
  16. ockevin
    ockevin Active Member
    493
    148
    Orange County
    That is Rodney's prius. AKA Hawaiinbuilt
    JMD likes this.
  17. Jeff Hubert
  18. Ursoboostd
    Ursoboostd New Member
    24
    Florence, Ky
    Hmmmmm. I might have to check that mount out.
  19. musicalhiccup86
    musicalhiccup86 New Member
  20. JMD
    3,779
    1,282
    Yep, that guy did a good job. It's not my car, saw it at a LA Prius get together.
