iPhone 4 can't pair w/ '08 Prius (iOS6)
Discussion in 'Gen 2 Prius Audio and Electronics' started by mdreinders, Oct 25, 2012.
  1. mdreinders
    mdreinders Junior Member
    Elm Grove, WI (Milwaukee)
    Have an '08 Prius w/ Bluetooth. iPhone 4 (not an S). Was running iOS 5.0.1. Was working fine paired to the Prius to make calls, etc.
    Wiped device and put on iOS6. Now, when both devices are 'searching' for each other, the Prius does NOT show up on the iPhone.
    I'm sure I did this same method the last time. Does anyone know if iOS6 is or is not compatible with the '08 Prius?
    Thank you for your assistance!
    Michael R.
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    My iPhone 4 with iOS 5 releases always worked fine over BT with my 06. My iPhone 5 paired and works fine as well.
  3. mdreinders
    Thanks for the reply. I actually tried it again this morning before going to work, and it paired! :) Sorry, I know I tried it again after it initially failed. But, this time, it worked. I'll have to see if it auto-connects going forward.
    Probably just a glitch.
    Michael R.
