iPhone 5 may be rebooting NAV on 2013 PiP
Discussion in 'Gen 3 Prius Audio and Electronics' started by reilogix, Oct 11, 2013.
  1. reilogix
    reilogix Get honor, and stay honor.
    23
    San Clemente, CA
    2013 Prius Plug-in
    I have a 2013 plug-in Prius with 14k miles. I am experiencing intermittent issues with NAV/Bluetooth system rebooting. I even took a video to show the Toyota service rep. I have an iPhone 5 running iOS 6.1.2 and I am jailbroken.
    I'll be driving along, maybe on the phone, maybe not. Intermittently and with no warning--poof--Bluetooth disconnects and the nav system reboots.
    Apparently Toyota is aware of an issue which may be due to a Bluetooth/power problem such as the iPhone BT is causing Toyota BT to overheat, or something to that effect.
    For the next week, I will turn iPhone BT off, and not use USB cable from car to iPhone 5. This is the next troubleshooting step and I will report back after.
  2. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I'm using iOS6.1 jailbroken and I don't have that issue. In fact, I've never even heard of something like this. My PiP is a 2012, so I've been driving for 16k+ miles and never seen this.
    My Nav needs to be updated, because I have that issue with the error that says not able to navigate from your location.. happens randomly. But other than that.. no other probs.
  3. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    I have an iPhone 5, and was running iOS 6 (not jailbroken) and now am running iOS 7 (also not jailbroken) in mt 2012 PiP Advanced and have never experienced the issue you are describing. Lexus has a TSIB for some 2014 IS250 and 350 that are experiencing the exact symptoms you describe. The fix is a firmware update to the NAV.
  4. reilogix
    23
    San Clemente, CA
    2013 Prius Plug-in
    If it affected many people, it would be a Service Bulletin or a recall, which it is not. nonetheless, Crown Toyota in Ontario, California has confirmed that Toyota is aware of this issue. Not with everyone, but with some people. More so on the Advanced model (which I do not have.) I will post a YouTube later today or tomorrow, showing this issue as it happens.
  5. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    No problems with 2012 Advanced & iPhone 5. Was on 6.5.2 (jailbroken/StraighTalk), now on 7.0.2 (not-jailbroken/T-Mobile).
  6. reilogix
    23
    San Clemente, CA
    2013 Prius Plug-in
    UPDATE: I've driven a couple of hundred miles since my original post, and I have not had the iPhone 5 connected. (Neither Bluetooth, nor USB, at all.) I have, however, had my iPad 3 connected via Bluetooth and USB at times. The NAV reboot issue happened once, just yesterday, when I opened the map. The iPad 3 uses Bluetooth version 4.0 just like the iPhone 5. Now, my next test will be to not use the iPad nor the iPhone.
  7. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Sounds like a good time to leave the dark side and join the Android revolution!
    Alright, just kidding i lovers :)
  8. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    That's not always the answer either. My AT&T LG E-980 crashes/reboots frequently when trying to open the charging map or just getting updates to Entune. It's very sporadic and not completely reproducible, but what a PITA.
    Toyota says the phone is completely compatible but at times, you could've fooled me. I've tried deleting the phone from the system and re-pairing but it's got a mind of its own. One day it works, the next it won't.
  9. ny_rob
    1,968
    813
    L.I.- NY
    Honestly, I don't think either OS is perfect when used with the Prius.
    If past issues are any indication- the problem is with Entune and the Toyota OS not the mobile devices.
    jdk2 likes this.
  10. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Couldn't agree more!
  11. CharlesH
    2,785
    1,152
    Roseville, CA
    I have not had any Entune or Bluetooth problems with my Blackberry. I understand that many consider Blackberry to be on it's death bed and not a viable platform, but the communications functionality in it works great.
    (Although the lack of applications is making me look real seriously at the Moto X Android.)
  12. reilogix
    23
    San Clemente, CA
    2013 Prius Plug-in
    Still having the problem. Took my car back to the dealer on appointment so that a guy from Toyota Corporate could come in and run some advanced tests. They are blaming my phone. They say it is a known issue with certain iPhone 5 phones. They said my only recourse is to call Toyota Tech Support at (800) 331-4331. I will report back my findings.
  13. reilogix
    23
    San Clemente, CA
    2013 Prius Plug-in
    Turns out that the (800) number is worthless. I talked to the service manager. The issue is well-known by Toyota staff. Apparently iPhone 4S and iPhone 4 on iOS5 are not affected. iOS 6, and iOS 7, and iPhone 5/5S also have intermittent issues. They consider this to be "operation as designed."
  14. CharlesH
    2,785
    1,152
    Roseville, CA
    That's the Apple philosophy. How the i-device behaves is by definition the standard, and other vendors just need to deal with it.
    A few years ago, the European Union passed a regulation stating that all mobile (cell) phones must use the same charging connector (micro-USB). Apple told them what they could do with their regulation.
  15. reilogix
    23
    San Clemente, CA
    2013 Prius Plug-in
    UPDATE: still dealing with the frustration of my navigation and Bluetooth rebooting multiple times per day, I finally switched back over to my girlfriends old iPhone 4S running iOS 6.0.1 and the problem has not come back since. I will update this post as the situation changes, however, it appears that either I have a defective Toyota NAV/BT unit or that indeed the iPhone 5 (or iOS 7) is causing the problem. :(
  16. drash
    drash Senior Member
    2,477
    1,252
    Upstate NY
    After a Kindle, several Palm handhelds, Sony Clie, Sansa Clips, 2 Blackberries, (and yes even a Microsoft Zune) and every manner of USB connector for those, I have to admit the new Apple USB connector is the one that should have been produced. Imagine inserting a connector either way and be correct, who would have thunk it.
  17. Tideland Prius
    16,128
    Have you tried borrowing another Prius with the 6.1" Display Audio for a day or two and see if it occurs on another vehicle? This could help narrow it down further to whether it's a defective unit on your vehicle or the DA 6.1" unit in general.
  18. reilogix
    23
    San Clemente, CA
    2013 Prius Plug-in
    Greetings, Tideland--
    I have not tested on another Prius, although that is a good idea. But, since Toyota has already acknowledged the issue, I think I may be out of luck. On top of that, I have already spent way too many hours on this project (due to switching phones, taking the car in multiple times, and testing with a host of iOS devices.) I know I will get to the bottom of it one day, but I'm not sure when. It seems that the iPhone 4S which I am using currently, does not cause the issue. Maybe that is my solution :(
  19. reilogix
    23
    San Clemente, CA
    2013 Prius Plug-in
    UPDATE: I've been using the iPhone 4S non-jailbroken on iOS 6.0.1 now for a few weeks, and I have 3 similar rebooting/freezing issues. I may have to stop using Bluetooth altogether, on my less-than-one-year-old car. Tired of the problems and unreliability.
    Next step: take a video of it happening again, and take it back to the dealer again, and leave my iPhone with them. Again.
    You'd think that a company with as many engineers (and dollars!) would be able to get this right. Or, license it from a company who has. :/
  20. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    I don't think it's your cell phone. Both my son's 2013 Persona Series AND my own 2012 PLugIN spontaneously restart every so often.For no reason I can figure.
    I have unpaired the phone from the car and used my in-ear headset and it's still done it. My son's on a Samsung Galaxy Note I think and I asked him to unpair his, still does it.
    It's Entune. Have they done the most recent update? Curious.
