iphone continued power on LONG trip
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fgp, Apr 29, 2016.
  1. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    im getting ready to do about a 1200 round trip to daytona and back to home in nashville. i just joined audible and will be listening to audio books all the way down. how do i hook up. the blue tooth works fine. im just wondering on a 12 hour trip if i just plug into ...well what exactly to keep going all that way without phone running out of power.
  2. drash
    drash Senior Member
    2,590
    1,335
    Upstate NY
    XLE AWD-e
    Just plug the iPhone's USB cord into USB socket in the front of the console between the front seats. It'll charge your phone and you can even use the phone via the USB plug as well.
    iPhone ?
  3. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    great answer. i was feeling that it would drain too much power for the usb to handle
  4. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    Playing audio while charging the iPhone works well, however using the USB port may take priority over Bluetooth.
    I use this AUKEY Car Charger which has enough amperage to charge while using GPS navigation apps and remaining on Bluetooth.
    fgp likes this.
  5. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    you know, i think i might just order one. they are cheap enough (about $13) and will take care of power and charge anxiety too. thanks
  6. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    did it....believe it or not amazon says it will be here may 1. i ain't bitchin thats for sure
