iPhone Questions
Discussion in 'Gen 3 Prius Audio and Electronics' started by stream, Jun 4, 2010.
  1. Tideland Prius
    16,678
    Oh I mean how you can tell it to play a particular track using that voice control on the 3GS.
    That's odd... so how come some ppl in this thread are saying they can do it and some can't? My netbook with, what i assume is basic BT, can skip tracks as well as volume (no text display though). Does 3G vs 3GS have something to do with it?
  2. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    It's a function of the Bluetooth stack that is being used by the OS. The iOS is using an older version of AVRCP stack. Your netbook is most likely running the latest especially if it's win7. Lots of discussions about this over on Apples forums.
  3. cmezriczky
    cmezriczky Junior Member
    34
    Austria
    Sorry was a misunderstanding, that works with USB Jack.
  4. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    When the 3GS is playing music through bluetooth you can use any of the normal voice control comands including artist, album, etc.. If it is hooked up by usb ipod voice control does not work.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Interesting. So if paired for BT music streaming, I can use voice controls to select, say, Dave Matthews. Will it then start playing the first Dave Matthews album, from first track to last, then proceed to next DM album, etc.?
  6. austingreen
    13,714
    4,232
    Austin, TX, USA
    Yes, just hold down the button until voice control comes up then say "Play artist Dave Matthews". The order depends on the order set up on your phone (mine goes alphabetical). If you have a specific album say "Play album Crash". Sometimes it gets confused but it will respond with "Playing album Crash", if it says the wrong thing try again.
    Also the pandora app works well for internet radio. Bluetooth music doesn't sound as good as plugging it directly into the port, but my brother was really surprised at how good internet radio sounded through bluetooth.
  7. stream
    2,977
    452
    Long Island, NY
    The button, meaning the voice control button on the steering wheel, correct?
    So you're using the iPhone's voice commands, but sending them through the Prius' sound system?
  8. Tideland Prius
    16,678
    wow, that is interesting. It might be more useful than skip track... since presumably, you can tell the iPod to go to the "Next Track" via voice commands.
    Ahhh ok. Yeah my netbook is running Win 7... starter version though... if that matters. Well austingreen said that the voice command works so it might not be so bad after all.
  9. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    This is my experience also. I love BT Streaming for podcasts and audio books but if I am listening to music it sounds much better through the line out jack (30 pin connector).
  10. larryt
    larryt New Member
    Silicon Valley
    austingreen doesn't seem to have answered you. I believe the answers are "no" (it's the Home button on the iPhone) and "maybe" (for some users, the car's speakers carry the call after the voice connection is established).
    I would have expected it to be possible to make the car's sound system simulate a BT headset, with the steering wheel button starting Voice Control. Apparently not. It would have been easy.
  11. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    Every time I try to initiate a call using the iPhone voice control, Bluetooth tries to route the call but immediately hangs up.
  12. BlueSmoke
    BlueSmoke New Member
    27
    Chicago Suburbs
    I am also having this problem. If anyone knows of the cause and/or a fix for this, I'd love to know.
  13. Ron K
    Ron K Junior Member
    61
    Yorba Linda, California
    Same issue with mine (I'll get a message the network disconnected) BUT I noticed that when I disconnect, the call then GOES THROUGH. It's as if the call is placed twice
  14. BlueSmoke
    27
    Chicago Suburbs
    When you disconnect the call goes through? Disconnect what? I get that message you get. I'd like to try what you're trying.
