iPhone too much power?
Discussion in 'Prius c Audio and Electronics' started by Ronnie80, Nov 4, 2014.
  1. Ronnie80
    Ronnie80 New Member
    When I plug my iPhone into the USB port sometimes a message pops up that says "The accessory uses too much power and will be turned off" Then a few seconds later my phone will stop charging, but then within a matter of seconds it will charge again and go on and off like this each time giving me the error message.
    2012 C- Three
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    which model iPhone do you have?
  3. Ronnie80
    Ronnie80 New Member
  4. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    the usb port is not and was not made for charging phones (or other things)
    buy a 12v accessory
  5. Ronnie80
    Ronnie80 New Member
    So what good is the USB port if you can't use it to charge your phone?
  6. SwhitePC
    495
    214
    ca
    a physical connection of your audio electronics to your car's audio system (there's this little option in the car's radio connection marked "usb")
  7. bisco
    52,725
    i plug my music stick into it.
  8. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i believe the usb in the car is rated at 500ma whereas the iphone needs at least 1000ma/1amp to charge. so the lower ma rating will cause the iphone to cycle thru the charging phase.
  9. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Are you using the Apple cable or a cheap one? I have a PiP and I've charged my iPhone 5 albeit really slowly. Best thing is to use Bluetooth and use an "iPad" 2.1 amp charger on the iPhone.
  10. HotDogWater
    HotDogWater Junior Member
    70
    17
    I've charged an iPhone 5 and 6 with the USB port with no issues for over a year.
    I did see that message you're getting one time, but it went away after I unplugged the phone and plugged it back in.
  11. GregP507
    GregP507 Senior Member
    3,002
    481
    Someone in a previous thread said it was due to using a non-factory cable: Entunes and iPhone 4s | PriusChat
    I'd never try to charge my phone with the USB data port, it was designed for the iPod. I keep a USB flash-drive plugged into that port. I use a USB adapter in the lighter socket for charging. Bluetooth works well enough for playing music from the phone.
    trentofdestiny likes this.
  12. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    I agree, I-phones draw more amps than allowed with a standard USB. I use a plug in charger so I can get the 1amp + that is used when driving with WAZE or GPS app. Look for a tablet which normally use 1.2 ampere for the larger screens
    iPhone ?
  13. AliIzad
    AliIzad Member
    170
    72
    Southern California
    Ensure you are using the genuine Apple cable; I had the same issue/message while trying to use a cheap knockoff cable; switched to the original cable and everything is fine. As for charging, my iPhone 5 is always plugged in via the USB port and it charges just fine; phone is always charged without any issues.
  14. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    The current draw on a properly working 5s is approx 0.49 Amps!! Unless there is some hig running in the
    No the phone only draws 1/2 amp, but that is the limit of that USB port.
    I have a USB cable with a Volt & Amp meter in it.
    Very handy!!
    OP you should use a different way to charge your phone!
