iphone x and etune, plus question about syncing addresses
Discussion in 'Gen 3 Prius Audio and Electronics' started by Matthew J Anderson, Aug 5, 2019.
  1. Matthew J Anderson
    Matthew J Anderson New Member
    Rochester NY
    I have a 2012 Toyota Prius with Display Audio with Navigation and Entune® App Suite. I have an Iphone X. However, the phone pairs with Bluetooth successfully, but I cant seem to get internet to work. I put in my etunes email and password when I try to set it up. Unfortunately, when I go to the Etune app and try to "connect bluetooth" with the car, it says "looks like we're still having trouble connecting... etc etc etc.... And when I go to press the apps button on the unit, then try to select "fuel prices," it says that the internet connection failed.
    I am wondering if the Iphone X is not compatible with this feature?
    I tried connecting with my samsung galaxy tab A, and I have no problems connecting to etunes with it.
    I am at a loss on this issue.........
    ALSO, another question! I wonder if it is possible to somehow sync google map, or on demand addresses to the navigation system in the car automatically as I drive for uber/lyft and other gig economy jobs. Is there a app that can enable this to be done, like a switching device/app that automatically exports every address to the system?
  2. Grit
    Grit Senior Member
    6,148
    4,058
    Wilkes Land
    You have to enable hot spot thru WiFi and Bluetooth on the iPhone. Sounds like your just transmitting audio thru Bluetooth, and have not enabled hotspot.
