iPhone X Plus and Prime's Qi Charger Pad
Discussion in 'Prime Main Forum (2017-2022)' started by schja01, Aug 30, 2018.
  1. schja01
    schja01 Senior Member
    1,867
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    Think the iPhone X Plus (6.5") will fit in the existing Prius Prime's Qi Charger Pad?
    The current one is 5.8"
  2. Nathanimal
    Nathanimal New Member
    San Diego
    I use a Galaxy S9+ and it fits in its case with room to spare. But the charger pad is slow and I only use it when the phone is almost at full charge. I have the 2017 Prime. Not sure if the 2018 was updated with a faster charger or if the 2019 will either...
    schja01 likes this.
  3. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    Nope. The current X barely fits.
  4. Njner
    Njner Junior Member
    2018 Prius Prime
    The X fits and the Qi charger sucks.
  5. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    Qi charging is only with 50% efficiency, half of the power will become heat and need to be dissipated.
  6. Njner
    Njner Junior Member
    2018 Prius Prime
    Yeah, I've got other chargers that are actually effective. The PP charger is terrible.
  7. followingalex
    followingalex Junior Member
    42
    New York
    My iPhone X gets hot and becomes slow and unresponsive after a qi charge on my Prius Prime.. makes me wonder if this is an iOS issue or just plain terrible charger … also noticed sometimes even when the phone is perfectly centered on the charger it just doesn't charge - I have to flip the charger's on/off button or move my phone out and back on and monitor that it is in fact charging.
    Anyone else see this? or did I just end up with a defective car charger?!
  8. schja01
    1,867
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    The few times I’ve used it (my prime is new) I have not noticed what you describe.
  9. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    nope, that's pretty much standard operating procedure... sometimes I have to repeat multiple times to get it to charge. I've pretty much given up on the Qi charger and now just plug in. I usually keep it on.. sometimes I get lucky and I throw it on the pad and it'll start charging right away, but usually no.
  10. schja01
    1,867
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    For those having problems how many have your phone in some sort of protective case?
  11. geguia
    geguia Active Member
    210
    108
    los angeles
    I've done both. It will eventually have an error charging. it's a bad charger.
  12. CharlesH
    2,798
    1,166
    Roseville, CA
    What the Qi charger in my Advanced does best for my Android phone is heat it up (and dribble a bit of charge into it as a side effect). I have a Tylt Qi charger, and with some modest care in placing the phone, it does a respectable job of charging my phone without heating it up too much, so the issue is not inherent to Qi.
  13. schja01
    1,867
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    Update:
    I picked up my iPhone XS-Max today and installed the Apple Leather Case.
    It fits perfectly in the Prime's Qi Charger.
    The phone paired with the Prime without any problems.
    Maybe 1/8" vertically and 1/4" sideways space to spare in the charger.
    If you have any of the iPhone Plus models (6+,7+,8+) they will fit as well.
    Enjoy,
    J
    Tideland Prius likes this.
  14. nanobozho
    nanobozho Member
    61
    38
    desplaines, il
    my 6+ in a lifeproof case does not fit...
    i have an xs max on order, do not expect it to fit either...
  15. schja01
    1,867
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    The pluses and max are virtually identical in size.
    The Apple cases add very little to the outside dimensions.
  16. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    Ditto everything said above (Xs Max w/leather case), except I have a 2017 Three Touring, not a Prime. No charging issues.
  17. coach81
    coach81 Active Member
    758
    116
    Louisiana
    When I test drove an advanced '18 my X fit just fine and seemed to charge with no problem even with a protective case.
