Ipod 4 won't charge in the car!
Discussion in 'Gen 3 Prius Audio and Electronics' started by Fore, May 5, 2012.
  1. Fore
    Fore Don't look back!
    494
    107
    Does anyone have a solution to charging their Ipod 4g in the car through the aux / 12 volt power plug? I do not have a usb connection in my base 2010 Prius. I've tried the usb convertor in the 12 volt power supply and it does'nt work. I also bought the Scosche passPORT and it didn't work either. Anyone have any cheap suggestions to get this old Ipod 4g to charge.
  2. Much More Better
    Much More Better Active Member
    655
    163
    12 volt to USB adapters are quite common. You can pick one up at TJ Maxx for $5. Then run a USB to 30pin cable to the iPod. You said you tried it though......
    Better yet, there are 30pin to USB + 3.5 stereo jack cables available on eBay for $5. That way you only run one cord from the iPod to the car that carries audio and power.
  3. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    Steve Jobs must not like Prii, or Flash.
  4. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    I have a cigarette lighter to iPod charger that I bought at 5 Below for 5 bucks. I connect via Bluetooth. Works great. I was worried that it might discharge faster when the car is off than it charges when the car is on but that appears to not be the case. I did have one instance when the iPod was totally discharged when I started the car but it charged in about 5 minutes and started playing music by itself.
  5. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    You might want to double check that the is working - it would be terrible to try all sorts of chargers only to find out that a fuse was blown.
    I have found that Apple products can be picky about chargers- if the voltage is not within a tight range it will not charge. My Android phone will charge on just about anything, but I need to make a point of plugging in my iPad to the charger it came with.
    I'd recommend going to a place like Target where returns are easy that way you can try it before being stuck with it.
  6. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    On major thing is the amp rating on the car device, make sure it is at least 1 amp, some are under rated for iPods, are you using the cord from the device, some cords do dont fit right and thus wont charge
  7. NiHaoMike
    NiHaoMike Member
    98
    16
    Some Apple devices need the data pins to be connected to resistor networks in order to charge, unlike other devices that only need the data lines jumpered or just charging whenever a valid power source is connected.
  8. pacohaas
    pacohaas Junior Member
    56
    I have heard some people have issues with non-apple cables. Are you using the cable that came with your device?
  9. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    You aren't going to get the right answer because there have been at least three completely different 4g iPod models:
    iPod Classic 4g
    iPod Touch 4g
    iPod Nano 4g
    iPhone 4g
    So until we know what you're talking about, you aren't going to get the right answer. But, if I had a guess, it's this: iPods used to support FireWire and USB. These two used different charging voltages -- 12v and 5v. Today, they only support 5v. Your iPod might not work with the 12v to 5v power adapter in your car. But unless we know exactly which iPod you have, it's all guessing.
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yep. See Identifying iPod models.
    Yep, I had a black and white 20 gig iPod 4th gen aka click wheel iPod. It supported 12 volt Firewire charging and came w/a Firewire AC adapter and Firewire cable. And, yes, Apple's moved to 5 volt USB charging only over time, and in all the current models.
  11. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I have a couple 12v-to-USB adapters in my car, and find only one works with my iPhone 4.
