IRIDIUM SPARK PLUGS
Discussion in 'Gen 3 Prius Technical Discussion' started by hotrod, Jul 2, 2017.
  1. hotrod
    hotrod Junior Member
    sarasota fl
    anyone using iridium plugs in their prius? 60k on our 2011 and i am going to change plugs. two techs from two different dealers (toyota and lexus) said to use iridium. tell me about you experience
  2. JC91006
    16,939
    8,647
    The original plugs are iridium and they are good for 120k miles. No need to change them at 60k
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    No doubt their markup is higher on "premium" plugs.
    There is no good reason to spend more money on plugs that are more expensive than what the OEM recommendation is.
    Especially if you are going to change them again (maybe) before the recommended interval.
    Despite the marketing claims, a spark plug is a spark plug and the main advantage of "rare metal" electrodes is longer life.
    P.S. While it may not be "necessary" to change the plug before 120K miles, I personally don't feel good about leaving them in there much past 5 years or 70K miles. Sometimes corrosion can happen making them difficult to remove.
    frodoz737 likes this.
  4. ChapmanF
    19,065
    Everyone is, unless somebody has replaced the OE plugs with the wrong stuff.
    -Chap
    CR94 and Mendel Leisk like this.
  5. ChapmanF
    19,065
    ... which is iridium ...
    ... longer life is part of the story; you can see the other part if you grab a caliper and measure the electrode diameter and compare. A non-iridium electrode would have a short life indeed if you tried to make it that skinny, and the voltage out of a Prius igniter was chosen with that electrode shape and gap in mind.
    ... and speaking of gap, another little PSA, don't try to gap the iridium plugs. They should be correct out of the box, and the electrodes aren't built to bend/pry in the field.
    -Chap
    CR94, m.wynn, jerrymildred and 2 others like this.
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I second that! Changed mine at 125k. mi and they were still fine.
  7. bisco
    52,923
    if anything, back them out, take a look, add some anti seize and put back in. use torque wrench.
    Simtronic likes this.
  8. Sam Spade
    2,036
    1,024
    2017 Prius c
    While that sounds logical it really doesn't make any sense.
    Once you have them OUT you might as well put NEW ones back in.
    Spread over 50,000 miles or so, the cost really isn't much.
  9. bisco
    52,923
    it's funny, some people agree, and others will travel to the end of the earth to save a dollar on an air filter.
    Anne8461 and frodoz737 like this.
  10. Mendel Leisk
    42,384
    Torque is 15 ft/lb with dry threads.
    Toyota makes no mention of anti-seize. My inclination is to put anti-seize on very sparingly, and reduce torque to 13 ft/lb.
    Socket size is 9/16" or 14mm. I've used 9/16", but I guess 14mm is kosher, and slightly tighter too.
    For sure watch @NutzAboutBolts spark plug video; there's a LOT of wrenching required, just for access.
    frodoz737 and bisco like this.
  11. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    I thought the OEM plugs were Platinum?
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Mine were all iridium. IIRC, the manual specifies iridium. Changed the wife's '07 at 118k miles, but they looked almost new. Changed my previous '05 at about 148k miles and three looked perfect and one showed minor wear.
  13. jerrymildred
    11,517
    14,171
    Tampa, FL
    Here it is. Confirmed in the 2013 PiP manual anyway: Screen Shot 2017-07-03 at 10.40.55 AM.png
    m.wynn, Raytheeagle and Mendel Leisk like this.
  14. bisco
    52,923
    see post #2.
    jerrymildred likes this.
  15. jerrymildred
    11,517
    14,171
    Tampa, FL
    Thanks. I did see it. I was just providing documentation to back it up.
  16. bisco
    52,923
    that wasn't for you, i always think it's funny when the correct answer is provided in the second post, but we just go on for days and weeks with various iterations. especially when the o/p never returns. doesn't happen over on ionique chat. that's what is so endearing hear, and one of many reasons why we can't leave.:cool:
    m.wynn, AzWxGuy and jerrymildred like this.
  17. jerrymildred
    11,517
    14,171
    Tampa, FL
    LOL!! We like to beat those dead horses till they finally get back up. And we have mastered the fine art of digression. ;)
    m.wynn and bisco like this.
  18. Prodigyplace
    12,720
    11,852
    Central Virginia
    Enjoy your Ionique. :LOL:
  19. bisco
    52,923
    nobody actually owns one, we're all just pretenders. in fact, i'm not sure there really is such a car. it might just be a subversive korean plot.
    m.wynn and Danny3xd like this.
  20. NavyLCDR
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Yep. My 2011 owner's manual actually says the same thing. Good thing I replaced mine with Iridiums! :)
