IRIDIUM SPARK PLUGS
Discussion in 'Gen 3 Prius Technical Discussion' started by hotrod, Jul 2, 2017.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Iridium is such a rare and unique element, I hate to waste it. I wish we could recycle the old plugs for Iridium recovery.
    In any case, changing them at 60k for no reason is a waste of an incredible substance/resource. I changed mine once at about 135k miles and I do not expect to ever change them again. And I still got the old iridium plugs.
  2. El Dobro
    El Dobro A Member
    7,106
    3,282
  3. Prius C Tom
    Prius C Tom Junior Member
    Michigan
    Just replaced my original iridium spark plugs with new iridium spark plugs after 143,000 miles. Runs a little smoother but fuel economy is the same. Old plugs were in good condition. Use iridium and replace them as recommended for a smoother engine performance. I waited too long.
    jerrymildred likes this.
  4. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    With the level of effort involved and long mileage between plug changes, using an inferior, cheaper plug seems like false economy to me.
    Tande likes this.
  5. Mendel Leisk
    42,384
    Just curious: does anybody know if fourth gen plugs can be extracted without removal of windshield trim, wipers, wiper motors/linkage and metal cowl?
  6. Prodigyplace
    12,720
    11,852
    Central Virginia
    @Elektroingenieur dohould be able to check.
  7. Mendel Leisk
    42,384
    Hurdle #1: Can the coil be pulled out; is it physically possible, or does it bump into the cowl too soon?
    Hurdle #2: Is it possible to fiit a ratchet wrench with some combo of extensions in there, and fenangle the plug out?
    Hurdle #3: Number's one and two are just possible, but at the end of it will you wish you'd just removed the cowl anyway?
    Prodigyplace likes this.
  8. Elektroingenieur
    2,515
    3,288
    Three Touring
    For fourth-generation Prius cars, the Repair Manual (more info) says to remove the No. 1 engine cover sub-assembly; front wiper arm head cap, arm and blade assemblies, and water extract shields; and the cowl top ventilator louver sub-assembly, before removing the ignition coil assemblies. I haven’t tried it, but it wouldn’t surprise me if the coil assemblies are too tall to come out with the other parts in the way.
    Prodigyplace and Mendel Leisk like this.
  9. Chaminda
    Chaminda New Member
    Sri lanka
    2014 Aqua
    I changed those from 97k as plugs too old and looks like corroded body. It costs 22k LKR + 13k tune up in hibrid hub sri lanka.
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    That is external rust? not sure if it is from plugs or exposure to elements, not sure it matters too much? Also sounds like you replaced early? not sure replacement interval recommendation.
  11. spiralhelix
    spiralhelix Active Member
    255
    220
    Illinois
    I was super glad to find out they changed the engine bay enough with the CT that nothing extraneous has to be removed to change plugs and coils.
    Going back to the first page (speaking of beating a dead horse), I can laugh now, but was super upset then, when Lexus told me that i had installed "inferior" plugs which were NGK iridium plugs and they wanted to replace them with denso platinum plugs. ummm Wth?!?!?!
  12. Mendel Leisk
    42,384
  13. El Dobro
    El Dobro A Member
    7,106
    3,282
    Lexus CT200h.
  14. bigblock67
    bigblock67 433K with new cells
    171
    35
    Indiana
    2002 Prius
    My 02 with iridium spark plug is .39 on #1 cyl and shows misfire. Told not to gap when new. What is actual gap supposed to be?
  15. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,100
    Columbia, SC
